Results 1 to 3 of 3
- May 2009
- 7
July 4th, 2009 10:11 PM #1Masters padistorbo po. sino po me sentra eccs? just want to know ano average consumption? got a 2nd hand 91 eccs matic recently. restored ko na and so far ok naman except for the consumption. medyo malakas kasi parang 6-8 km per liter lang takbo combined city and hiway driving. was thinking of bringing it to a casa for a consult (tama ba yon?) would this help? would appreciate your advice... thanks!
July 13th, 2009 09:42 AM #2
Check all the maintanace procedure to lower fuel consumption:
1. Spark plug .
2. Distributor Timing
3. spark plug wire
4. clean throttle body
5. Fuel filter
6 Change oil
7. Change automatic transmission fluid
8 Check grounding kit
Check all before doing a consult just in mind if you have a properly maintain car your fuel consumption wil lbe lower and drive moderately and do a weight reduction. Hope this help.
- May 2009
- 7
July 13th, 2009 11:53 AM #3thanks a lot sir. will do this po. will let you guys know if there are improvement after doing the maintenance..more power
Normal po Yan saken inde bababa need pa re start everybody can share same as my experience so I...
high idle RPM at engine start
