Results 1 to 2 of 2
- Nov 2008
- 35
December 7th, 2008 12:09 PM #1mga paps ask ko lang, what could be the reason para palitan ang timing chain ng nissan.ang pagkaka alam ko kasi timing chain could last compare to timing belt ng other engine.
December 7th, 2008 02:49 PM #2
Ideally a Timing Chain should last the life of the engine. Severe oil starvation or a gross manufacturing defect are the only things that are likely to cause chain failure. If the engine did lose oil pressure it is possible the timing skipped due to a lack of oil pressure to charge the Hydraulic Tensioner for the Timing Chain. If that is the case then the timing needs to be reset, the chain itself should be OK. If the chain is actually on the outs it is likely the motor will fry before the chain fails - the timing will be off after all.
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
