Good day experts! My car is a 1999 nissan sentra series 3 A/T. About 2 weeks ago, I checked its spark plugs to see if they're already due for replacement but I forgot to put back 1 of the high tension wire boots resulting in the car's abnormal idling and loss of power. After I changed the spark plugs, the car functioned normally for more than a week.
Until I noticed that the car's engine was "choking", so I had it checked by a mechanic who diagnosed that the compressor's pulley is not in proper alignment anymore causing the engine to choke. He replaced the compressor's pulley and belt. The car seems to function well at this time.
But after I brought the car home, I noticed that it's engine has some sort of "skip beats". I checked the spark plug wires and I found out that one of the boots is damaged. So i changed it with a Mallory brand "replacement" high tension wire, whose cable's diameter is a little bigger compared to the original part. Despite this replacement, I still notice occasional "skip beats".
My car's fuel filter is newly replaced and the spark plugs are new as well. What could be the cause of the "skip beats"? Could the diameter of the cable be the culprit?
Looking forward to your expert opinions. Thanks!
