Page 117 of 186 FirstFirst ... 1767107113114115116117118119120121127167 ... LastLast
Results 2,321 to 2,340 of 3900
    Oct 2004
    hmm i dont think na masisira naman yung makina just by changing the filter .... ewan ko lang kasi yun nga as ive said dati, bkit masisira ang component if all your doing is improve it? like yung filter, gusto mo lang mas free flowing at de mo na kailngan palitan lagi, so ok ang same as the spark plugs from stock papalitan mo ng iridiums which is better and yung brake pads na from stock to ebc greenstuff.. pero kanya knaya na yan hehehe
    Jul 2005
    Thanks for the suggestions! Nung basahin ko mga comment sa australian forum nagdecide na din ako mgpalagay. La pa daw nagka-problem sa mga ngkabit nun, and most have good things to say about it. Sa Nihhon banawe available siya for 3500. Pakakabit ko bukas, hopefully makita ko din yung difference. Hehe, akala ko kasi lahat kayo ngpakabit na nun kaya hinanap ko sa banawe.
    Oct 2004
    caloymd: np ! im really sure na walang problema na mangyayari dyan
  4. #4
    doc caloy: balitaan mo na lang kami kung may improvment sa fuel consumption and performance
    Jun 2005
    i agree with kmo, i dont think something bad will result to the change in better airfilter, otherwise, sira na pangalan ng knn. I suggest doc caloy that you replace them both at the same time para mas malaki improvement...
    Jul 2005
    Actually gusto ko nga isa-isa ang palitan ko (whether plugs, filter, tire pressure, or gas octane) para nakikita ko kung san galing improvement (parang sa gamot, hehe -- kung madami ka binigay na shotgun approach, di mo na alam san talaga galing improvement).
    Pinakabit ko yung dynamats sa front speakers, nabawasan nga ang vibration (kaso dinig pa rin yung vibration sa likod). Also found out what speakers came stock with the "premium sound system" -- 40w panasonics. Waaahhhh...
    Hirap na, daming pwedeng palitan!
    Aug 2005
    anong magandang panglinis ng engine? dumi na kasi eh, mostly i think nagsamang alikabok at putik. hindi pa kasi ako naglilinis ng engine eh except dun sa lumang kotse.
    Feb 2005
    Quote Originally Posted by erict
    Moist basahan lang yan and a paint brush. Huwag mo basain.
    Aug 2005
    Quote Originally Posted by zeagle
    thanks Zeagle, akala ko may binibili pang separate formula na engine cleaner. heheheh.
  10. #10
    - APC + Water mixture (1:10 dillution)
    - cover the alternator and MAF sensor with rags and plastic (just enough to repel water)
    - don't power wash or use high pressure water spray.
    - warm up the engine for a couple of minutes
    - spray the APC + Water mixture on the engine bay, use brush to aggitate dirt and grime.
    - use light running water to rinse.
    - wipe down the engine, if you have compressed air then use it on the hard to reach places. Thats it. HTH.
    Aug 2005
    *ILD, tanong ko lang po kung ano yung APC?
  12. #12
    erict: all purpose cleaner. Try looking for Simple Green * True Value. Its Citrus based its safe on rubber parts like hoses, etc.
    Aug 2005
    Quote Originally Posted by ILuvDetailing
    thanks ILD!, tamang tama pupunta ako ng Filinvest mamaya, makabili na nga.
    Jul 2005
    helo fellow Xtrailers! kamustas?!! long time na di ako nakapag-post. by the way, so far I'm really enjoying my ride, haven't done any mods as of now. I've tried na ihataw sya ng 180kph coming from a speed of 100kph. ang bilis umkyat ng ng speed at palo agad ng 5T ung rpms. Very stable sya at dat speed (considering na maganda din kasi ung hi-way). Kaso ang odo meter ko 3900 na 1 n half month plng xty ko. hehehehe, sarap kasing ipang-gala.
    Oct 2004
    buti pa dyan maganda ang highway. dito maraming sorpresa sa daan lalo na ngayon panay ang ulan.
    Aug 2003
    mga pare, pag nagpalit ba ng lowering springs mare-resolve yung mababa yung likod? by the way magkano pala lowering springs? thanks!
    Oct 2004
    Quote Originally Posted by 4var
    di naman mababa ang likod. optical illusion lang yon. tingnan mo yun linya ng bottom ng body mo against the ground. hindi lubog ang likod.
    Jul 2005
    jonnyd: yes sir, maganda talaga kalsada d2 dahil sa buong taon eh ilang araw lang ang ulan dito kaya ok sa pang-ilalim, No worries sa rust. Naalala ko dati nung di pa ayos ung North express satin, daig pa ang buwan sa mga pot holes. ang lalalim pa. (jolens!!!) hehehehe. SARAP I-RIDE NG XTY!
    Oct 2004
    4var: mababa ang likod?? d naman mababa ang likod a mas mataas lang wheel arc ng harap kaya tingin mo mababa yung likod and i dont recomend na mag lowering springs ka stock mags kasi naranasan ko na yun sandali lang ng pero sobrng baba talga lalabas tska sumasayad yung tambutso sa mga humps
  20. #20
    4var: baka naman may mabigat kang karga kaya ganon? IMO Lang, bili ka ng SUV tapos ilolower mo? it defeats the purpose of a utility vehicle.
Nissan Xtrail Owners: Questions and stuff
