Page 102 of 186 FirstFirst ... 252929899100101102103104105106112152 ... LastLast
Results 2,021 to 2,040 of 3900
    Aug 2005
    so paano yan? nde qualified mga Xty natin? pero pwede yung old Honda Civic? ganun ba yon? parang mejo malabo yon
    Oct 2004
    Quote Originally Posted by ILuvDetailing
    qualified pa ba kami? eh wala pang 1 year xty namin.
    may lusot pala yung 2-yr rule. pwede mong i-register as primary car yung iba kahit na ibang brand. eto yung response nya:
    Bro, if / they have other vehicle na more than 2 years old pwede na gamitin yun as primary vehcile registered sa club. Kung non-nissan kahit 1 day old pa lang pwede iregister as primary vehicle, plate number nga lang nun ang lalabas sa card and not your x-trail but you can register your xty as secondary vehicle and still enjoy all the perks of the club.
    tuloy ligaya natin dyan.
    Jun 2004
    saan ba yun mantrade? hehe.. walang discount kung sa ibang branch magpagawa?
  4. #4
    Kailangan pa ba dalhin yung primary vehicle para macheck?
    Oct 2004
    di na siguro. copy lang siguro ng registration ok na. may application forms yata sa mantrade. look for patrick. sya ang contact natin sa NB.
    Aug 2005
    Quote Originally Posted by johnnyd
    pwede ba yung old car ng brother in law ko ang ipa-register? or dapat nakapangalan din ang registration ng old car sa akin?
  7. #7
    johnnyd: Member ka na ba? try ko pumunta sa 15Tkms Service.
    Oct 2004
    di pa bro pero baka kumuha na rin ako ng application form. baka damihan ko na para sa ibang kasama natin.
  9. #9
    Teka, sa dad ko yung paparegister ko pwede kaya yun?
    Oct 2004
    zeagle: pangit ng xtrail dun sa taiwan ! mukahng palaka hehe pero maganda yung interior sobra ! hehe well try m nlng amghanap ng strut bar dun ! kahit generic! kung may mahanap ka mas mura sa 6.5t kuha kna hehe kuha mo narin ako hahahaa
    Feb 2005
    KMO: Baka kasi may magandang accessories ng Xtrail na kakaiba e makabili. Hehe may mags kaya maganda dun na orig?
    Feb 2005
    1) The intake manifolds are of a variable design. The short intake runners are only opened only when 5000rpm is reached, otherwise, only the longer intake runner is used throughout. Should we expect a big kick in the butt when we reach 5000rpm? Also, I wonder what it'd do to boost performance if the ECU is remapped to open the 2nd shorter intake runners at a mere 4000rpm and also at the expense of fuel consumption!)
    2) The counter rotating balance shafts are actually rotating at twice the speed of the rpm you're at. So, it means that when you're doing 5000rpm, the counter balancer shaft is actually rotating at 10,000 rpm!!! According to the lead designer, Inamijima San, the balancer shafts would be safe spinning even past 20,000 rpm but the rest of the engine parts may 'fly' apart.... ahem...
    3) Our crankshafts are micro polished for max efficiency and min. friction.
    4) Our engines being much bigger in displacement than the previous ones by Nissan, is actually up to 10kg less in weight!!! Thanks to lesser part count and also aluminium precision die-casting technology. However, the drawback would be the open deck design being fragile when pushed far beyond it's designed capabilities. So, careful guys...don't overdo it ...haha. Some recommend that turbocharging be left out at best. Perhaps Nissan is still working on a light pressure turbo charged version of the QR series? Cos the Xtrail GT employs the SR20VET, the worlds first turbocharged variable valve lift & timing engine...or issit?)
    5) The fuel system is returnless as in most new cars.
    6) Fuel pressure is fixed at 50psi...yes... no variable pressure to suit manifold pressure...so we can forget about fixing the rising rate fuel pressure regulators in turbocharged systems.
    7) No manual (and easy) advancing of the distributor to gain extra bhp...
    8) No more valve shims used for adjusting lash. That means less mass, less maintenance of valve shims that wear out and make iritating noises (like my previous Toyota SEG)
    From Malaysian Forum
    Oct 2004
    hmm mags as in nissan parin? or aftermarket na talga? kasi dati meron dito nagbebenta mags daw ng 350z ata or altima binebenta sakin e baka gusto mo kasya e satin
    Feb 2005
    Gusto ko yung pang GTi ng Japan pa rin
  15. #15
    zeagle: kailan alis mo? Pasalubong namin ha
    Aug 2005
    my brother's xtrail consumes 7-8 km/li, masyado malakas engine nagspin tires pag bigla sa gas pedal, kulang traction ng gulong, we changed it to slightly wide tire gumanda traction, baka it has something to do with the consumption. also tire pressure plays big part sa consumption eh, and good sparkplugs
  17. #17
    sonny: does your brother drive a 4 x 2 or 4 x 4 200X or 250X model?
    Feb 2005
    ILD: Sa Monday alis ko. Cge uwian ko kayo ng kiamoy.
    Oct 2004
    hahaha zeagle ako seaweeds hehe dami dn hehehehe tkaa strut bar hehe jk
    wala ka at amahahanp dun na gt ! tignna mo sa nissan taiwan na site
    sama ng xtrail nila
    Jun 2004
    baka meron kayong stock na hu ng xtrail dyan?hehe
Nissan Xtrail Owners: Questions and stuff
