hello pips,
clueless po on auto maintenance...
where and how much po ba ung change of timing chain;tensioner for nissan vanette?
thanks!!!
hello pips,
thanks!!!
AFAIK, kung timing chain na ang Vanette, then there's no need to replace it, even yung tensioner bearings. Yung cars na equipped with Timing BELTS lang ang pinapalitan (pati na run yung tensioner bearings). Hintayin mo lang masira.
Yung Sentra Series 3 ko, 10 years kong ginamit before I sold it in 2006. Never replaced the timing chain and tensioner bearings, but even after logging a mileage of 110,000++ kms., tahimik pa rin.
Matagal po kasi masira timing chain, nasa loob kasi sya kaya ginawa sya durable.
Ano po ba problema?
Our Vanette is just over 10 years old now and I have not changed its timing chain..... There are no telltale signs that it needs replacement, anyway.....
7303:soda:
Tama po si sir Galactus, belt lang ang pinapalitan, pero kung chain, napakaliit ng chance nya masira agad if normal use lang ang car. Bakal po kasi ang
if you want to see a timing chain, eto po sya. Not same car, but ganyan looks nya. Also try looking for more related vids po.
[ame="http://www.youtube.com/watch?v=9txar03I6uM"]YouTube - Timing chain?[/ame]
[ame="http://www.youtube.com/watch?v=W5FI6FFCzc8"]YouTube - timing chain[/ame]
BTW, welcome to tsikot!
Madali namang malaman kung pasira na ang timing chain. Since gawa ito sa bakal, maingay ang engine bay. Pero if you don't notice anything naman, no need to change it. Timing chains should last the lifetime of the car, provided the engine isn't abused.
sir blizzard,
wow! may vid p---thank po ha!![]()
umuulan lng d2 s men, no covered garage, d q p msilip...hehehe...
sir galactus,
may nrrinig dw po cla ingay...pero wla nman ako npansin, or bka d lang aq mxado aware...
promis, ppkinggan ko na po!![]()
same problem din po na encounter ko sa 1994 vanette ko. kailangan po tlga i-replaced ng timing chain and tensioner dahil malatad na po ang chain nya. yun po pati ang pinagmumulan ng pagkasira ng timing gear.
