Results 1 to 11 of 11
    Dec 2009
    Hi Mga Sirs,
    Newbie po ako dito ...I have a problem on my nissan series 3 ex saloon flooded po siya but everything was already restored for 2 months mahigit ko na hindi nagagamit yung auto. Here's the problem po...Nagsastart siya and when the gas was stepped on yung 2rpm tapos steady siya parang humihinga tapos pag tinry namin na paandarin using first gear pag umabot ng 2.5 yung rpm nya na jejerk yung car and ganun din po pag 2nd gear and pinasok...saan po kaya problem nalinis naman na yung throttle nya...possible po kaya na computer box na yun or yung fuel pump lang? if ever meron po na kayo masusugest na mabibilan yung mura lang sana kasi wala na po ako budget para sa car eh. sana po mabigay nyo sakin yun contact number anyway south area po ako.
    Thanks po sana matulungan nyo ako.
    frankly, i do not understand what it is you are trying to say. kindly re-phrase your statements. then, maybe you will get responses.
    but if it is what i think it is, well, i had the same problem before. at first i thought it might be fuel starvation. dinala ko sa casa. they replaced the entire distributor assembly. ok na. try also to replace your hi tension cables.
    Dec 2009
    Dr. D
    Salamat po sa respond... ganito po yung problem nya pag start nung engine normal po yung andar nya pag straight rev ok din po, pero pag nag steady lang yung paa sa gas at around 2 ang rev taas baba po sya from 2 upto 2.5...pag tinry ko sya i abante aandar sya pero hanggang 2.5 lang ang rpm after nun nagjujump sya or parang mamamatay engine pag nilagay po naman po sa 2nd gear ganun pa din po hanggang 2.5 lang... same po ba tayo ng naging problem...? thanks po sa advice...
    Quote Originally Posted by marky_mark00016 View Post
    Dr. D
    its with the maf bro, its either it needs cleaning or its faulty.
    other probable causes are electrical-related like high tension wires, sparkplugs, etc.
    Dec 2009
    thanks mga sirs...check ko po yan...possible po ba na MAF sensor yun kahit sealed yung pagkakadikit nya kasi nilinis na rin po throttle at tska servo eh...? most probbably ndi po tlaga ito malfunction ng computer box...? hirap po ksi i trouble shoot eh...may idea po ba kayo kung how much yung maf sensor or distributor...? spark plugs po kasi nya bago din eh... thanks po sa reply sobrang laking tulong nyo sakin...
    Iyong maf sensor pag marumi dahilan din iyan kaya nag babago ang rev mo kahit steady paa mo sa gas pedal. Iyong maf sensor kasi nagkokontrol ng idling mo pag nagbukas ka ng mga accesory sa sasakyan headlight , aircon additional load kasi sa makina ito. Linis lang kailangan riyan sa MAF sensor.
    Dr. D
    mukhang iba. yung akin, ok ang idling. nguni at kapag subukan kong gumalaw na at tapakan ang silinyador, ay parang sinisinok na wari ko'y kulang sa fuel. wala akong oras at pasensiyang mag-trouble shoot, kaya pina-ubaya ko na lang sa casa.
    Feb 2009
    Dalhin mo yung auto mo sa J Brothers sa may pasig, ok yung gumagawa dun... kakagaling ko lang dun last week, bali servo problem naman ako... ang ginawa nila is nilinis yung servo then may pinalitan na hoss (for air intake yata ito)... ito contact nila... J Brothers Motor Service Tel. No. 6715313/6715284 look for Eng'r Mario Nara.
    OT lang po:
    Mga sir, san ba kau nagpapamaintenance ng sentra nyo?
    Sir Speed_unlimited,
    I havent made up my mind pa pala dun sa Nissan ST with redtop SR20, inoffer kasi ng bayaw ko ung 1994 GLI nya for 100k lang. Practicality: Corolla Porma/Fun: Nissan ST Lalo tuloy ako nalito ngaun
    Dec 2009
    Dr. D
    ipa-check mo nga un MAF sensor. 3 weeks ago e nagpapalit ako ng MAF kasi pag naka-hinto oto ko tapos ni-rev ko ng steady lng e biglang uugong un makina na parang palyado. kung sa ilaw e parang nagfluctuate. 4500 bili ko sa evangelista ng surplus.
nissan series 3 need help badly
