Results 1 to 4 of 4
    Feb 2005
    Help Please! Bumababa yung idling ng sentra na ito. Pag-nagpreno ka, babagsak ang idling at mamamatay ang makina. Di pwede bitawan ang accelerator, kung hindi, mamamatay or sobrang baba ng rpm. Anybody has any idea what could cause this problem? Automatic 1991 model nissan sentra. Anybody encountered this problem and successfully resolved it?
    May 2007
    Quote Originally Posted by chizcake71 View Post
    Although i dont have any nissan background, you might want to consider checking if nissan has what we call an idling servo that controls the idling within 800-900rpm.
    good luck.
    It's a common problem on ageing Nissan EFIs (as well as with any ageing EFI vehicle).
    Do first the following:
    - tune-up
    - intake plenum/manifold cleaning
    - AAC valve cleaning (Air Actuator Control)
    - MAF sensor cleaning and reground (Mass Air Flow); have a Nissan CASA check if it's calibrated properly through their CONSULT computer.
    - Change your high tension wires if (spark plug wires) this had not been done in over 5 years.
    Pare Pakicheck Mo Yung Brake Booster Mo Baka May Singaw Na. Check Mo Check Valve Nyan Kasi Kumukuha Ng Vacuum Nyan Sa Intake Manifold. pag patay makina mo, press mo yung brake mo. dapat titigas yan. pag malambot, may problem po. sana makatulong to. tnx
Nissan Sentra SS 91 Problem
