Results 1 to 11 of 11
    Parang makina ng Nissan Skyline yung nakalagay. hehehehe.
    Just Click Here
    Tindi naman ng pagkaka-convert ng rear suspension. From leaf springs ginawang inverted single leaf, dual shocks with coil overs and independent links!
    Ang mahal siguro niyan...
    Kayang kaya mo naman yan. :D
    yoli-inspired..
    nyahahaha..
    Maganda tingnan...but will it last sa regular off-roading? I think the rear suspension look weak....I would have followed the set-up of the rear suspension of a safari patrol or an LC80 (big coils/shocks and those thick metal links)....
    The front is body lifted (right?!)...since the front part of the chasis could be seen (tama ba ang tingin ko).
    The front A-arms are good....mukhang talo ang design ng Fabtech.
    Jan 2003
    parang chassis make over ah...ewan! what are coil overs and independent links? Ano ang ginagawa niya sa suspension?
    If you look under rear suspension of the pajero and (gen 2 newer) and or safari patrols...yun ang coils and independend suspensions.
    Hindi matagtag ang ride ng nakaganitong suspension set-up and they usually have better articulation than leaf-spring setup.
    grabe.
    ganda nung suspension nung frontier.
    magkano kaya aabutin yun?
    sulit na pang-trailing
    hehehe.
    Jan 2003
    ang ganda nga ng upgrade...asteeg....kaso parang mahina ang construction ng springs...iisang leaf lang??? ako nga nasiraan ng stock leaf spring yan pa kaya??? :D
    Di naman kasi for loading purposes yung modifed single leaf conversion. Kaya don't expect the modification to load heavy stuffs like you do.
Nissan Frontier:  Lift and Flex
