Results 1 to 9 of 9
- Jul 2009
- 3
July 19th, 2009 03:31 PM #1Good day sirs, need your help regarding my exalta's leaking sunroof.. Can you please guide me on where i can have it fixed? I already called nissan mantrade and was told that i have to leave the car and wait for about 2 - 3 days. You guys might know a shop that could help me.
Thanks a lot guys and more power!
July 19th, 2009 10:09 PM #2
I have no particular shop in mind but if you know a shop would know to check the drain path of the sunroof, have them check that. It might be clogged due to debris or dried leaves. Another probable cause could be a worn out sunroof rubber seals (if ever, the first I've heard for such a model)
- Jul 2009
- 3
July 20th, 2009 07:04 PM #3yup. just check the drain path. i was able to fix mine last week when i removed some dirt that blocked that drain path
- Jul 2009
- 3
July 20th, 2009 07:14 PM #4Thanks for the reply guys really appreciate it...I cleaned the drain path this morning and try to see if it works..
July 20th, 2009 07:53 PM #5
That is a common problem with sunroofs. Tama sila, baka may bara lang sa drain. However, if that cleaning the drain fails, baka sa rubber housing na nito. The sun's heat can really stress the rubber, lumulutong.
- Jul 2009
- 3
July 22nd, 2009 02:14 AM #6cleaned the drain path and still theres leak...I think its the weatherstrip na siguro.. Baka you guys know where i can have it fixed.. thanks again
July 22nd, 2009 02:21 AM #7
Have u tried applying silicon sealant? It's just 100 bucks per tube. You'll probably consume only 1/4-1/3 of the tube. The caulking gun should be around 100 pesos+
- May 2004
- 903
September 24th, 2009 11:36 AM #8is this common to all exalta with sunroof? We are planning to purchase this model soon... or the newer model of sentra is better?
September 24th, 2009 12:05 PM #9
Subukan mong dalin sa Aguila Glass windshield shop mas kabisado nila ito . Marami silang mga rubber para sa sunroof . at kaya nilang gawin para mawala ang leak.
Automatic po Sir
