Results 1 to 10 of 19
- Nov 2009
- 5
November 30th, 2009 07:47 AM #1Hi All,
Could anyone help me on what to do with the prob that I have with my car.
Para po cya nabubulunan pagnagshft from 1st gear to 2nd. Lalo na pag dadahandahanin ko apak ng accelerator.
Pinalinis ko na po carb same pa rin cya. Natanggal ko na gas saver but ganun pa rin.
Any ideas anyone?
Your help would be greatly appreciated.
Thanks.
November 30th, 2009 08:22 AM #2
Check mo spark plug , distributor, high tension wire kung magandang magbigay ng kuryente at tamang timing ng makina at iyong air filter baka marumi na.
- Nov 2009
- 5
November 30th, 2009 08:37 AM #3Tnx po sir but already tried those.
2x na ako nagchange ng spark plugs n air filter this year dahil sa prob na2.
Though ung tension wire tsaka distributor inde ko lam kung nisama ng mechanic.
Madalas po cya mangyari pagnaka aircon ako. Possible po ba din ung throttle body na marumi? may nabasa kasi ako sa page 3 just now about na parang same sa issue ko?
Tnx po ulit.
November 30th, 2009 09:00 AM #4
- Apr 2007
- 97
November 30th, 2009 10:21 AM #6
Your engine is carburator type as what you said so there is no throttle body. Its only on electronic fuel injection engine .
November 30th, 2009 11:07 AM #7
check mo mga hoses ng carb baka may natanggal o naikabit sa ibang port
November 30th, 2009 11:35 AM #8
- Aug 2008
- 129
November 30th, 2009 04:58 PM #9I think your carb unit needs to be cleaned and adjusted. Baka marumi na yan. Just my 5 cents.
November 30th, 2009 06:27 PM #10
go to basic first
1- check high tension wire
2. distributor -
3. Air filter
4. Fuel filter
5. Clean up carb
6. Spark plug .. ano ba spark plug nalagay mo
7. check fuel line too
8. CHeck / adjust Idle
9.
-- pag on mo ba aircon nanginginig ng malakas?
-- baka nakapag pa gas ka ng E10 hindi mo lang naaalala ( E10 not compliant sa carb)
One feature they should incorporate in EVs is speed limiting based on the keyfob you hand over to...
