Results 1 to 12 of 12
    Aug 2009
    I have a nissan sentra series 3.. After ko magpaoverhaul lumakas na kumain ng gas.. 4 liters of gasoline ubos agad ng less than an hour.. Nakabukas lang ang makina.. Any idea kung ano problema nito? I need your help guys.. I need your suggestions..
    Apr 2004
    ano engine mo? carb of fuel injected.
    pag carb yan you're overfueling, baka hindi maayos alam ko medyo tinotono yan. masama yan sa bagong overhaul, i suggest you bring it to a competent mechanic kung hindi maayos ng nag overhaul (kung hindi nya maayos yan, i'm sure hindi din maayos ang overhaul mo. bye bye bank account).
    Aug 2009
    Quote Originally Posted by voltscastillo View Post
    fuel injected siya bro..
    Feb 2005
    bro, how did you figure out that it consumes 4 liters in less that an an hour?
    Aug 2009
    Quote Originally Posted by zman View Post
    we load 4 liters of gasoline after overhauling it.. We just keep the engine runing and the engine stops less an hour.. Then we load again 4 liters and the same thing happens.. Do you have any suggestions?
    Apr 2004
    in my experience, huminto dati yung 4d56 na newly overhauled ko after about 30 minutes on the 1st start after putting the engine back together. the reason wasn't overfueling, but oil starvation (patay! pag tanggal nung top rocker cover tuyong tuyo!).
    how's the temp? steady ba? hows the idling? choppy? try loading more fuel, and don't run it at idle so you can break it in. it's a bad idea, because the gas goes nowhere and washes down the bores, preventing the rings from sealing. where do you think all that gas goes to? it's not all going to the compression/ignition process, thats for sure.
    your spark plugs turning black is a sign of too much fuel, too little air. either that or its oil fouling the tips. try adjusting the idle mixture until the exhaust doesn't smell like petrol. if its oil fouling you are in for some more bad news, sir.
    my top 4 things to check:
    1. air/fuel mixture (yes even EFIs have the screw adjuster thingy)
    2. gas blowby (see if there's excessive vapor from the oil filler cap while engine is running)
    3. timing
    4. leaks in the fuel line to the fuel pump (baka maluwag nung kinabit)
    4.
    Apr 2009
    woah sobrang lakas yan! ako tumaas idling medyo me problema ako di ko mababa (me post ako) pero nakakaatain parin ako ng 12km/l sobra laklak yan di kaya idling mo nasa 1500rpm na?
    Pa check mo kung tama ang timing . tignan mo iyong sunog ng sparkplug mo . Kung maitim hindi masyado nasusunog gasolina . Tignan mo bawat isa spark plug kung hindi maganda sunog . Hindi maganda ang pagkaka overhaul nito.
    Aug 2009
    Quote Originally Posted by speed unlimited View Post
    sa timing kahit i-advance o i-delay ko siya tumataas baba lang yung minor ko.. Yung sa spark plugs naman lagi siya nangingitim.. Saan sa dalawa yung dapat tutukan ko? Salamat bro..
    Aug 2009
    Quote Originally Posted by kulotz View Post
    todo na idling ko.. Below 1000rpm na lang.. Pero kusa siya tumataas tapos bumababa.. Pati daloy ng kuryente taas baba din..
Need help with my ex saloon [drinks gasoline]
