Page 4 of 4 FirstFirst 1234
Results 61 to 71 of 71
    Aug 2016
    im going to replace the brake hose in the front driver side. tapos sira na din ang metal brake line that connects the front driver side brake hose to the master cylinder...
    magpapa-fabricate ako ng brake line kaso hindi na tama ang bends niya
    would anyone have pics of good condition brake line or kahit crude drawing lang para magaya? thanks in advance...
    Aug 2016
    just a few updates on this thread:
    replaced the brake lines with copper tubing:
    new master cylinder:
    Original nissan oil cap and coolant temp sensor:
    transmission mounting broke (loose thread):
    (no image due to tapatalk limitation)
    transmission repaired:
    flywheel resurface:
    and lots more!
    just a bit more left: shocks, shock mount, rear wheel bearings, front brake caliper, caliper bracket, and rotor, body repair and paint.
    Shout out to BF auto parts in paranaque for all your advice and help!
    I cant believe ive done all of this myself! i only expected na ang makina lang ang mapapatakbo ko, and the rest mekaniko na lng...
    Nice thread sir, I'm currently in the process of restoring a 1999 Sentra B14 Super Saloon A/T. Ganda pa kasi ng body at interior. Nastuck lang for 6 years as the car was involved in a relatively minor accident (sa harap, nawasak hood, tama bumper, umurong paharap na bengkong condenser, but radiator is still okay).
    Bumili ako front cut sa Evangelista, 14k. So bnew lights, bumper other parts na kinahoy. Yung grille gusto ko kasi Lucino type.
    Quote Originally Posted by carguy101 View Post
    im also planning to buy a new fuel pump assembly, mahal kaya yun? kapag fuel pump only lng kasi 1.2k. baka abutin pa ako ng 10k if yung buong assembly.
    Tumawag ako sa Nissan PH, the entire thing costs P14,000.00
    So ang ginawa ko, checked eBay USA, ito yung nabili ko: Herko Fuel Pump
    Okay naman performance nya so far, problema lang dito wala shang low fuel sensor, at medyo pangit yung clamps, so ang ginamit namin ay yung Sentra orig clamps from the orig fuel pump.
    Issue: Ayaw gumana ng speedometer, not sure kung gawa matagal na stuck up o sira na, bumili narin ako bnew speed sensor from US na din.
    Napatakbo na namin yung kotse, okay padin. Still idling as it was bnew (replaced oil and filter, ATF, brake fluid).
    Things to do: palit shock absorber /CV boots (joint kung talagang durog na) / painting last.
need advice on reviving sentra series 3
