Results 1 to 10 of 71
- Aug 2016
- 252
August 29th, 2016 03:16 AM #1mga boss, need advice sa pag-revive ng sentra ko na supersaloon, matagal na kasi nakatambak yun naisipan kong patakbuhin na.
stuck up na yung makina, i removed the spark plugs para lagyan sya ng penetrating oil. paano ko ba papaikutin yung makina?
tapos yung clutch nya kung tapakan ko di na umaangat, ano ba dapat tingnan ko kong ganun? pati na rin yung gear shift lever nya di na gumagalaw... paano ko din ba gagawin yun?
1996 nissan sentra nga pala sya na supersaloon at manual transmission
thanks in advance.
- 52,512
August 29th, 2016 09:57 AM #2i do not see any problem.
if the car was running fine before it got mothballed, there should be no major issues in resurrecting her. nanigas lang ang lubrications.
your only limiting factors are, how much money are you willing to go, and where will you get the good mechanic?
i guesstimate 30K at may sukli na yan.
good luck, po.Last edited by dr. d; August 29th, 2016 at 10:08 AM.
- Aug 2016
- 252
August 29th, 2016 12:57 PM #3hindi pa kasi bulok ang ilalim at ang katawan, i was actually surprised to see that its still in good condition. makintab pa yung paint after years na nasa ilalim ng puno!
i was planning on making it run myself so i dont have to spend too much on a mechanic since i have a bit of experience in fixing cars...
i was also thinking na engine, transmission, suspension, and brakes muna unahin ko. last na ang paint.
- Jun 2005
- 3,762
August 30th, 2016 10:48 PM #4Change oil ka muna. Tapos try mo i-crank yung engine manually dun sa crankshaft. That should release yung pistons kung stuck. Tanggalin mo muna spark plugs para mas madali icrank.
Kung di macrank, lagot na. Malamang may sira engine like tukos valves or sirang bearings
- Jan 2015
- 468
August 31st, 2016 12:30 AM #5
sir dagdag ko lang, kung mag change oil ka ibaba mo na ang oil pan then linisin mo na din. inspect mo na din makina kung may tulo if tama pagkakaalala ko ga13de ata makina niyan, sakit niyan is the valve cover gasket lang naman.
pangilalim, ihuli mo na yan, ang importante mapatakbo mo muna makina then you can check the transmission (change oil na din) - tama si sir sirkosero, manual rotate it sa crankshaft.
then clean the intake, since carb yan bugahan mo na din ng cleaner ugn carb bago mo machangeoil.
- Aug 2016
- 252
August 31st, 2016 09:48 AM #6
- Aug 2016
- 252
August 31st, 2016 09:51 AM #7
- Aug 2016
- 252
September 1st, 2016 10:11 PM #8does anyone know kung saan ang oil filter ng sentra? or does it even have an oil filter?
- 52,512
September 2nd, 2016 05:41 AM #9errr... under the engine? in the usual place where japanese engineers put it.
it is shaped the usual way japanese engineers design oil filters. easy to ID.
easier to work on, if the car were up on a lift.
if you're going to work on the oilpan, "it's just there, beside/near it, screwed to the engine block".Last edited by dr. d; September 2nd, 2016 at 06:05 AM.
- Jan 2015
- 468
September 2nd, 2016 07:12 AM #10
see my pahabol statement above. i mean, i can go on vacation anytime. but my spouse has her...
Traffic!
