Forums
Discussions
Events
Community
January 8th, 2009 02:38 AM
Hi people......
Kaka change oil at tune-up lang ng LEC namin 1 week ago.....
Palit mga filters at oil......Palit ng spark plugs......Repair Kit on the Carburetor....and palti ng mg hose dun sa Carburetor......
25 minute test drive na tapos ok naman
But after that.......Nung ginamit na ng mga kapatid ko......Tumaas yung idling.....as in sobrang taas talaga na ang ingay na nung tunog ng makina.....
3 beses na binabalikan ng mechanic to to re-adjust the idling.......pero it keeps on going back to its ultra high setting.....
Ano kaya problema nito?
January 8th, 2009 03:41 AM
1. How exactly did you do exactly with your carburator?
2. Did you check the timing?
3. Did you use the correct O.D on the hose?
4. Did you tighten the hose clamp?
5. Did you touch the throttle position sensor? If did, reposition the sensor.
6. Did you adjust the idle?
January 11th, 2009 08:23 PM
2 Mekaniko na tumingin eh.........
Pero wala silang gnawa kundi i-adjust ang idling.....
But after a few seconds na umaandar.....Bumabalik sa dati ang idling
Can anyone here refer a Reliable and Trustworthy mechanic na nag hohomeservice tapos kabisado talaga ang NISSAN LEC?
Help mga bro
January 12th, 2009 08:45 AM
Bring your car back to your mechanic to adjust back the idle screw. Bought a carburator cleaner and have it clean the trottle to clean all the gunk in the carburator. Sounds like you have a dirty (sticky) throttle, check the gas pedal too.
