Results 1 to 4 of 4
    Apr 2009
    i hope someone could help me to find where in the engine i can find the MAF sensor of Nissan Exalta 2000 STA? thank you for your time.
    May 2007
    kung parehas tayo ng engine (granduer), tabi sya ng airfilter box, nasa loob ng tubo papunta sa makina/manifold.
    sa labas mapapansin mo meron nakaconnect na wire sa tubo.
    Quote Originally Posted by alexisolid View Post
    It is located in the metal tubing right after the filter box. If you can remove it, you can see a small hole beside the big main air way. That small hole leads to the sensor.
    If you plan to clean it, be very gentle and use only contact cleaner that doesn't leave any residue. Don't spray at it too close.
    Apr 2009
    hey guys! thanks for your help... i appreciate it very much... God bless!
HELP! where can i find Exalta MAF Sensor?
