Results 1 to 7 of 7
    Mar 2013
    help guys !
    So here is the story,
    Friday Night, I had my car gassed up in morato, that night , after gas while I was in neutral the engine suddenly turned off by itself rpm dropping weirdly , the morning after same story until today while I was near Wilson, again on neutral it stopped and turned in then turned off until about my 5th try the car started I had this weird sound sa tambutso Na parang may pumuputok Na like cough sound. . Di naman hard mag start up once Lang nangyare yung paulit ulit. May water kaya yung ginas?or sa engine Na?thank you
    Nissan Sentra Gx 1.3
    possible na may water or expired yung gas.
    palyado ba pag ni revolution?
    Aug 2003
    pwede ring barado yung fuel filter, or it could be starting to disintegrate, sending particles into your engine. This happened to me around twice, parang suminok yung car at random. Replaced the fuel filter, problem went away.
    My first thought is bad fuel, given i came out after you gassed up. Try draining your tank and changing your fuel filter first (quick, habang mura pa gas).
    idling speed too low?
    fuel injection system too "sakal" ? walang air.. too much fuel..
    whatever it is, i feel it needs just an adjustment and not a parts replacement..
    Sep 2019
    ganito problema ko ngyon..anyone dito makapag provide sa akin ng itsura ng fuel filter?newbie kasi ako nalilito ako sa mga version ng nissan..thanks
HELP: Nissan Sentra Gx Engine suddenly turns off
