Results 1 to 6 of 6
- Dec 2010
- 4
December 5th, 2010 02:56 PM #1at problem wala sya sa timing mag change ng gear madalas nababad sa 1st at umiilaw ang power button kahit hindi ko press ang power button pero pag press ko ng hold button ok sya normal ang shifting bakit kaya ganun?
- Jan 2011
- 5
January 29th, 2011 12:28 AM #2Ganyan din ang problema sa Nissan Mistral namin. Pero mas malala na ang kondisyon sa amin ang starting gear niya ay 2nd gear hindi na sa drive hindi na kakagat ang Drive.
- Dec 2010
- 4
July 2nd, 2011 03:12 PM #3nagawa ko na ung prob ko sir nag adjust lang ako sa may injection pump ayun nadali ok na sya hehehe...
July 2nd, 2011 04:28 PM #4
Any chance that the problem may be the transmission? When was the last time you had the transmission oil and filter changed?
- Oct 2012
- 1
October 30th, 2012 06:02 AM #5subscribing po, ganyan din problem ko.puro 1st gear ayaw mag shift.paano po nag adjust sa injection pump?. tnks
- Dec 2010
- 4
January 15th, 2013 11:23 PM #6adjust ka sa tps makikita mo nakakabit sa injection pump may 2 screw un adjust mo lang using voltemeter engine running lagay mo sa 20v voltemeter mo saksak mo ung lead sa center at side ng tps harness mo makikita mo ung volts reading kailangan nasa 0.5 to 0.75 volts depende sau try mo lang it works sakin
Burberry Men Leather Jacket oskarjacket
Verifpro - paypal, ebay, banks, crypto, docs and...
