Mga Tsikoteers. I'm a newbie po dito sa Tsikot. I just want to ask for opinion/help about the problem of my car.
Nagpalit po ako last year ng clutch disc, cover and release bearing. After testing napansin ko nagda-drag siya on the first gear so ibinalik ko ulit sa mekaniko. Ibinaba ulit nila yung transmission then ni reface yung flywheel. After a test ganun pa din... sabi ng mekaniko intay ko daw muna lumapat yung disc. Kaso a year na ganun pa din and napansin ko pati sa reverse ganun na din. Lalo kapag paahon ako umaatras parang may gear na kumakabyos.
I want to know kung possible bang pagmulan ng drag ang cv joint, draglink at rackend? Bago ko ipapaba ulit ang transmission. Mahal kasi ng labor for this.
question po: what does "drag" mean?
does it mean, parang nakatapak sa brake? maybe it is. brakes are stuck?
does it mean, clutch is slipping? some clutch assemblies and clutch disk / pad have front and rear surfaces. hindi kaya baligtad nai-kabit? has the clutch cylinder been bled correctly? baka may hangin.. has the clutch pedal been adjusted correctly?
i'm sorry kung tama yung term ko na "drag", what happening kasi is nanginginig po at certain portion sa pag-angat ko ng clutch pedal.
with regards sa brakes pinachek ko na and ok naman. sa clutch disc naman i'm not sure kung may front and rear surface siya kasi iniwan ko lang sa kanila yung sasakyan. tapos di cable type po yung sa akin (sentra b14), hinahangin din ba kahit di cable? kasi sinubukan ko i-adjust yung clutch cable then napansin ko lang kapag ibinaba ko yung clearance parang nag-i-istuck up yung pedal, tagal bago bumalik pataas.
Kung cable type ang clutch mo kailangan i adjust sa tama Para kung nasa first gear ka kaunting taas mo sa clutch uusad agad sasakyan mo. Kailangan rin i bleed kung may hangin .
