Results 1 to 10 of 18
Threaded View
Tsikot Member Rank 4
- Feb 2004
- 1,704
November 2nd, 2004 05:49 PM #1guys, i have read about coil spring spacers for the safari. the most common size available on the net is 30mm in height.
if i installed this on a safari, would i be able to accommodate 33" tires? what else needs to be done to accomodate 33" tires? any other tips and tricks that i must perform to keep it performing like stock? do i need to change shocks?
as you guessed, i want a small lift on a tight budget to fit 33" tires on a safari. hope you guys can help me.
and if the coil spacers are the way to go, where can i get it them? meron ka ba nito pareng Glennster?
thanks,
andy
If that's the case, then hindi rin pala lahat ng nakaka-afford sa kanila ay hindi frugal mag-isip...
2021 Toyota Land Cruiser LC300
