Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
    May 2010
    I'd recommend TOP1. It's a very good performing engine oil. since you've both 10w-40 oil already, it would be fine with your engine.
    Jul 2011
    Been seeing lots of good review about top1 though i havent tried it for the longest time. One of this day i will try it out again.
    May 2010
    Top1 is undeniably the poorman's Motul oil as what i call it. It is almost at par. Yun lang, there are only few variants to choose from. But if i were to pick between Royal Purple and Top1? I'd pick the latter.
    Quote Originally Posted by SiRbossR View Post
    sir, care to share your good experience with top1?
    May 2010
    I always use Motul, Mobil, Royal Purple and Martini oils in my cars. but then i read and researched about Top1 and learned about it. I first tried it in my Ranger and there was difference in idling, engine heat(the heat that you feel when you go in front of the car after driving), fuel consumption, the sound of the engine revving up was smoother and Engine vibrations and noise was reduced.
    top 1? parang nakikita ko sa ace hardware ito ah... kahit anong brand basta yun viscosity pwede sa kotse niyo and regular oil change ok yun...saka kung hinde umiitim yun engine oil niyo then matakot kayo dahil it's not doing what it's supposed to do...
    TS punt aka sa thread ko tingnan mo mga replies doon about oil changing
Change Oil
