anybody knows what chip the 2001 nissan patrol (diesel) uses?
need to buy a replacement as the chip on the original key broke off and got lost.
it might be the same for lower models. is that the key with one button (for lock/unlock)? i was able to get a blank key and transponder from Nissan Balintawak last 2009 for an exalta GS grandeur.
you will need to leave your car there for reprogramming for the key to work (both ignition and keyless entry).
You can try checking out L.O.M. key in greenhills...they might have a blank key in stock. I'm not sure though if the key they have has the transponder built in.
i need somebody to give me info on the kind of chip. they say i need a key with a chip 46 in it to work with the 2001 nissan patrols. can anyone confirm this? or can anyone pm me, contact info on someone who would be knowledgeable on the issue? thanks
Try going to any Nissan Dealerships. That's the only place where you buy it and have the key reprogrammed to work on your car.
Had ours done at the Nissan dealer before (bought the key and transponder + reprogram). Cant remember the price back in 2002 but it was less than 5K all-in back then.
Please check out Home - Car and Motorcycle Transponder Duplication in the Philippines for all your transponder key needs.
We can clone your working key, and cut you a key (code cutting) in 30 mins.
