Results 1 to 11 of 11
    Aug 2009
    mga sirs,
    im a newbie driver, just have bought a 95 altima pag po pumalo nasa 100 un rpm nia nagwiwiggle po siya, kapag maniobra or lubak may mahina sipol sa left driver side tires, san po ok na mechanic here in manila i just live in pasay
    sana po ma help nyu ko haay
    thanks.....
    dalhin mo sa servitek. most likely your alignment lang. Pero since you just bought the car, why not have the underchassis components checked (tie rod, balljoints, rack end). Don't bring your car sa Rapide ha? Me malapit kasi diyan.
    Quote Originally Posted by georgeousairess View Post
    mga sirs,
    thanks.....
    baka 100 kph?
    check your wheel balances, tires, rims, and wheel allignment first, kung hindi yun, pacheck mu na suspension (bushings first then so on...) at power-steering assembly
    1. pacheck mo under chasis mo kung may sira palitan yun dapat palitan
    2. after under chasis saka pa lang ipa camber alignment
    3. kelangan din wheel balancing
    4. check mo rin tires mo baka meron isang oblong
    HTH
    Aug 2009
    THANK U MGA BOSS HAAY
    your welcome!! update mo kami if ok na kotse mo
    Aug 2009
    mga sirs ok napo un takbo niya dami pinaltan sa unahan wheels front,
    wheel bearing, velocity joint,power steering, shocks bago nadin, brake pads, haay laki gastos hehehe dugo dugo bulsa ko hehehe
    mga sirs as of now 2 nalang problema ko engine support nlang po and un velocity joint un para maliit na bola sa loob ng gulong kasi un isa maliit san po ba pwede makabili nun un daw nakaka tunog sa car ko since ala pa sila part na ganun pra remedy nalang nilagyan nila maliit na velocity joint kasi kulang napo.
    haay nakahinga nadin
    so next week likod gulong naman haay,,,,
    ask ko din lang po mga sirs for altima owners magkanu po kaya un engine support na nagastos nyu based on your experience
    thank u mga sirs
    Mar 2007
    o.t.
    sir pwede po ba pa post ng pics yung altima ride nyo? Im planning to buy one kasi sooner or later po,if pwede pasilip narin ng interior at engine bay ng model 95 altima thanks
    goodluck din po pala sa mga troubleshooting nyo
    my replacement engine supports are just prefabricated. inabot lang ako ng 800 petot lahat. pero sa casa and normal price na qoute sakin is asa 16k.
    georgeousairess pedeng pabreakdown po ng gastos? saka kung san po kayo nagpaayos?
    engine support 16k sa casa wow!! ang mahal mas mahal pa kesa sa mga brand new car ngayon...
    sa mga auto supply siguro di ka abutin ng 1k isa depende kasi sa engine support yan..front and rear,,left and right ang ang front pinakamura sa sa nissan lec nasa 280 lang...ewan ko lang sa altima
    sa tingin ko sobra pa ang 5k labor materyales na yun 4 na support pa yun kung sa auto supy mo lang lahat bilin..save mo na lang ang 11k
Altima 95 wiggling need help
