Results 1 to 12 of 12
    Aug 2005
    Hi guys,
    I don't know anything about bikes.. So I need a suggestion.... What to you recommend that will fit by budget...
    Here are my other requirements.
    1. 2nd hand (Japan and not China)
    2. Motorcyle daw and not scooter (not sure on this ... pero sabi ng driver ko mas safe daw ang motorcycle over the scooter)
    Purpose.. This will be used by my driver for his personal transport.
    I was checking the buy and sell add.. Ok ba yung honda wave 100??
    Honda Wave okay lang reliable , matibay at maraming piyesa na nabibili.
    Aug 2005
    Quote Originally Posted by speed unlimited View Post
    My driver told me that the honda wave is a scooter.. So kapag naaksidente medyo delikado baka magtuloytuloy ikot ng gulong kasi wala daw clutch lever..
    Aug 2010
    Quote Originally Posted by imperialv View Post
    ahhh..TIME FOR me to Help naman..lagi ako tanung ng tanung dito eh..
    Heto Po yan...
    Scooter - walang Kambyo, accelerator lang..piga ka lang ng piga, Brake yung dalawang lever sa manibela
    Semi-Matic - May Kambyo po yan, pero walang Clutch lever - dito po nabibilang yung Honda Wave 100, pwede syang mag shift ng gear basta bitaw sa gas. Pag bitaw ng Gas mag Engine Brake naman po yan
    Manual Bikes or Clutch Bikes - Heto po hanap ng Driver nyo..Sa baba na po choices
    Suzuki Shogun PRO 125 CC (Double Disc Brake) - may U BOX / iba po yung Shogun R Semi Matic po yun ...
    Suzuki Raider J PRO 110cc MAGS, no U box-
    Suzuki Raider 150 wala din U Box - medyo hindi na praktikal kung hatid hatid lang. Mabilis, Malakas sa gas
    Kawasaki Fury 125 R
    (Double Disc Brake)
    Yamaha Sniper/Clutch 135cc
    Unfortunately wala pong may Clutch na ni release ang honda Phil for Underbone category..unless gusto nyo ng pantra...or kumuha from Thailand
    Hope makatulong!!!
    Aug 2010
    Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
    Aug 2010
    pero dahil po sa Budget nyo..
    heto po choice na swak sa Budget nyo..
    yung 2 generation ng 2nd hand na Suzuki Shogun PRO .. 3rd Gen po yang nasa taas..
    125cc
    Double Disc Break na din
    Magwheels
    Clutched...
    Aug 2005
    How much naman yung sinabi mo?
    Actually I saw an add 2004 Honda Wave 100 for 19T.. Ok na ba yun?
    Aug 2010
    ranging from 20-30k po yung Suzuki...it may vary on what is installed and mileage..
    But Stick to Stock to be safe..
    19k Honda Wave 100 is not bad, that's Semi-Matic though...but how is the bike? Performance? Handling?
    If you'll settle for Wave get the Wave 100R ..this has a Disc Brake, unlike Wave 100 which is using Drum Brake for front wheels..
    May 2010
    19k is not bad BUUUUUTTT..
    Do this first...
    1. Visit the unit.
    2. Check the mileage
    3. Do some test drive
    4. Check the engine and other parts (baka kasi pinangkarera yung unit tas nangahoy na lang ng parts para mabenta lang)
    5. OR/CR kung orig (dami kasi nagbebenta talahib ang papers ng motor)
    Para meron kang choices visit these link -> http://www.motorcyclephilippines.com...ieds/index.php
    Feb 2009
    honda tmx is also a good motorcycle. you can also choose kawasaki barako or a suzuki mola125/150. just make sure it is not used as pampasada by its previous owner/s as it may be nearing the end of its useful life.
    ok na yon. just have it inspected by a good mechanic. then, i-test drive mo. if it is well-maintained by the previous owner, then, ok na ok pa yon. my yamaha crypton is already 10 years old but runs well.
    or better alternative dyan is honda xrm - mas maraming available na parts - i think this is the best-selling motor cycle nowadays.
LF motorcyle with 20T to 30T budget
