Results 1 to 5 of 5
    anybody hir could help me, i want to tune up my motorcycle susuki raider 110, can some one give me guidelines or tips how to do it,
    thank you so much guys...
    and the tools needed... thanks
    Jan 2010
    Renfox, did you found what you want to know? I have the same problem with my suzuki shogun r 125. Can you help me and reply my blog. Thank you.
    madali lang pareho yan. kaso not much for the raider 110cc. you should have bought the 150cc with clutch. or the 125.
    anyways, panung tune up ba gusto niyo sir? tune up? or set up?
    kung set-up, physical ba or internaL? dame din kaseng set up sa motor eh.
    Tune up Suzuki Raider :
    1. Change oil . Any 4T motorcycle oil tools needed Wrench size depend on the drain plug . 1000Km to 1500 km interval of oil change or read your motorcycle manual.
    2. Change spark plug
    3 Adjust the air fuel mixture of the carburator.
    How , Run the motorcycle in a normal temperature
    set the idling to a low then adjust the air by using screw driver to reach the higher idling . This give the motorcycle a good acceleration response.
    thats all you need to tune up your raider .
how to tune up susuki 110
