Honda PCX 125i. Cruiser Scooter export from Thailand to the world.
2011 Honda PCX Specifications
May 12 2010
Model: PCX125
Engine Type: 125cc liquid-cooled single-cylinder four-stroke
Bore and Stroke: 52.4mm x 57.9mm
Compression ratio: 11.0:1
Valve Train: SOHC; two-valve
Induction: PGM-FI with automatic enrichment
Ignition: Digital with electronic advance
Transmission: Honda V-Matic belt-converter automatic transmission
Suspension Front: 31mm hydraulic fork; 3.5 inches travel
Rear: Unit swingarm; 2.9 inches travel
Brakes Front: Single 220mm disc with three-piston caliper
Rear: Drum with CBS
Tires Front: 90/90-14
Rear: 100/90-14
Wheelbase: 51.4 inches
Rake: 27.0o
Trail: 86mm (3.4 inches)
Seat Height: 29.9 inches
Fuel Capacity: 1.6 gallons
Estimated Fuel Economy: 110 MPG
Colors: Pearl White, Candy Red
Curb Weight*: 280 pounds
*Includes all standard equipment, required fluids and full tank of fuel--ready to ride.
I tested driving this yesterday he bought it used for 130.000. It accelerate like a 200 cc scooter and it has and idle stop . If your on traffic the engine dies automatic and when you press the accelerator the engine start on and continue to run . Fun to drive even if you have a back ride weighing 180 lbs.
