Results 1 to 10 of 22
January 31st, 2008 09:03 PM #1
Ang pogi nito, hindi na kailangan pormahan.
For more info http://paultan.org/archives/2008/01/...sia/#more-5505
February 1st, 2008 02:23 AM #2
gwapo talaga! 130k-140k ang price nya. nagtanong ako sa honda dealer, imported daw yan...hindi dito gawa sa atin.
February 1st, 2008 06:11 AM #3
dami din nag bebenta ng 2nd hand unit around 110 to 115K
at ang mga earlier model may 95K pa
February 1st, 2008 06:30 AM #4
dati type na type ko ang cbr150 pero dito ako nag lalaway ngayon sana ilabas sa Pinas ito
R-series engine and chassis technology
6-speed gearbox
Aluminium swinging arm
Midship muffler
Engine -
Engine type: Liquid-cooled, 4-stroke, 4-valve, single cylinder, SOHC
Displacement: 124.66 cc
Bore x stroke: 52.0 x 58.6 mm
Compression ratio: 11.2:1
Maximum power: 11.0 kW (15 PS) * 9,000 rpm
Maximum torque: 12.24 Nm (1,25 kg-m) * 8,000 rpm
Lubrication system: Wet sump
Carburettor: Fuel injection
Clutch type: Wet, multiple-disc coil spring
Ignition system: TCI
Starter system: Electric
Transmission system: Constant mesh, 6-speed
Final transmission: Chain
Fuel tank capacity: 13.8 L
Oil tank capacity: 1.15 L
Chassis -
Chassis: Steel Deltabox
Front suspension system: Telescopic forks
Front travel: 130 mm
Rear suspension system: Swingarm (monocross)
Rear travel: 125 mm
Front brake: Single disc, Ø 292 mm
Rear brake: Single disc, Ø 230 mm
Front tyre: 100/80-17 M/C
Rear tyre: 130/70-17 M/C
Dimensions -
Length (mm): 2,015 mm
Width (mm): 660 mm
Height (mm): 970 mm
Seat height (mm): 818 mm
Wheel base (mm): 1,355 mm
Minimum ground clearance (mm): 155 mm
Dry weight (kg) 126.5 kg
tsikotilyo
- May 2005
- 473
February 1st, 2008 07:09 AM #5^^^ hindi ba parang yzf r6 yan? ang ganda mapepeke ka,magkano naman ang price niyan?
February 1st, 2008 12:46 PM #6
February 2nd, 2008 08:20 AM #9
- Apr 2007
- 298
February 2nd, 2008 01:39 PM #10yung yamaha pang europe market lang daw yun mga sirs, malabo na ilabas dito at kung icoconvert daw yung price niya from euro eh aabot daw ng almost 300thousand including importation from the europe factory baka nga lagpas 300thousand depende sa customs taxes dito.
http://www.yamaha-motor.co.uk/produc...t/yzf-r125.jsp
yung cbr150 naman puwede daw creditcard ang pagpurchase sa triumpjt sa caloocan.
ito naman po yung link
I think the weight ratio between the vehicle and the driver will have something to do with it....
Wheel Alignment
