Ang pogi nito, hindi na kailangan pormahan.
For more info http://paultan.org/archives/2008/01/...sia/#more-5505
gwapo talaga!130k-140k ang price nya. nagtanong ako sa honda dealer, imported daw yan...hindi dito gawa sa atin.
dami din nag bebenta ng 2nd hand unit around 110 to 115K
at ang mga earlier model may 95K pa
dati type na type ko ang cbr150 pero dito ako nag lalaway ngayon sana ilabas sa Pinas ito
R-series engine and chassis technology
6-speed gearbox
Aluminium swinging arm
Midship muffler
Engine -
Engine type: Liquid-cooled, 4-stroke, 4-valve, single cylinder, SOHC
Displacement: 124.66 cc
Bore x stroke: 52.0 x 58.6 mm
Compression ratio: 11.2:1
Maximum power: 11.0 kW (15 PS) * 9,000 rpm
Maximum torque: 12.24 Nm (1,25 kg-m) * 8,000 rpm
Lubrication system: Wet sump
Carburettor: Fuel injection
Clutch type: Wet, multiple-disc coil spring
Ignition system: TCI
Starter system: Electric
Transmission system: Constant mesh, 6-speed
Final transmission: Chain
Fuel tank capacity: 13.8 L
Oil tank capacity: 1.15 L
Chassis -
Chassis: Steel Deltabox
Front suspension system: Telescopic forks
Front travel: 130 mm
Rear suspension system: Swingarm (monocross)
Rear travel: 125 mm
Front brake: Single disc, Ø 292 mm
Rear brake: Single disc, Ø 230 mm
Front tyre: 100/80-17 M/C
Rear tyre: 130/70-17 M/C
Dimensions -
Length (mm): 2,015 mm
Width (mm): 660 mm
Height (mm): 970 mm
Seat height (mm): 818 mm
Wheel base (mm): 1,355 mm
Minimum ground clearance (mm): 155 mm
Dry weight (kg) 126.5 kg
^^^ hindi ba parang yzf r6 yan? ang ganda mapepeke ka,magkano naman ang price niyan?
yung yamaha pang europe market lang daw yun mga sirs, malabo na ilabas dito at kung icoconvert daw yung price niya from euro eh aabot daw ng almost 300thousand including importation from the europe factory baka nga lagpas 300thousand depende sa customs taxes dito.
http://www.yamaha-motor.co.uk/produc...t/yzf-r125.jsp
yung cbr150 naman puwede daw creditcard ang pagpurchase sa triumpjt sa caloocan.
ito naman po yung link
[quote=BoEinG_747;1001041]dati type na type ko ang cbr150 pero dito ako nag lalaway ngayon sana ilabas sa Pinas ito
ok na sana to at maporma kya ung tunog lng engine ayaw ko pra syang lawnmower ung panggapas ng damo.hehehe
Ganda ng Yamaha na yan ah. Kaso daming mga siraulo na drivers dito, delikado. Kahit gaano ka kaingat, malapit ka sa disgrasya![]()
wala sa europe nyang yamaha na yan.. thailand at malaysia lng yan. walang europian na gagamit ng 125cc o 150cc. asian country lng gumagamit ng ganyan.sa middle east nga eh 250cc pinakamababa sa knailang pang deliver sa fast food eh. tapos 125cc europe mo gagamitin. di nagkandudulas kn nyan sa snow. 600cc lowest dun. 400cc ATV nila. ung yamaha FZ15 250k PHP. kaya yang 125 mga 200k. FZ15 may nagbebenta nyan 250k php.
sa marikina malapit sa stadium brandnew, tindahan talaga cla ng motor. bili kayo ng malaman nyo kung maganda nga. hehe. maganda porma kaso pag nadinig mo n ung tunog parang tricycle.hehe.. mas maganda CBR. mura pa.
wow almost look like my R6, it may not be as powerful but for sure as fun as a R6
as far as i know, the downpayment for the cbr 150 costs around 50k and the monthly amortization for 12 months is around 11k. if you opt to pay it for 2 years, the monthly amortization is around 7k.
