Good day! Need reco for shops na expert/sanay mag-alis ng old anti-scratch sticker sa door step sill without damaging the paint. Thanks in advance.
Hot air blower or pouring hot water (not boiling). It softens the adhesive and makes it easier to remove.
Just be careful you don't melt anything made of plastic, fabric, or rubber using hot air.
Hot water has always worked for me whenever I remove adhesive stuff from a vehicle. Pasensya at Tyaga -tyaga Lang Ang kelangan.
Nasubukan ko na dati air blower - failed. kabado ako baka ma-damage ko clear coat
Try ko hot water ... 2011 old vehicle kaya kapit na kapit un 3M sticker
I agree that hot air has more potential for damage if you're not careful. But it is still the fastest way. The trick is to avoid keeping the heat pointed at the same spot, rather, you sweep continuously over the item you want to remove and make sure that the heat is evenly distributed.
Just use hot water. My kuya taught me this. Never failed.
Sent from my SM-M127F using Tapatalk
