Results 1 to 12 of 12
    Apr 2016
    as the subject or title said, is there anyway to make the door sound like brand new, the refrigerator sound and feel
    Also nahihigpitan b ung door handle kc mejo maluwag and kumakalansing pag sinasardo or umaalog
    Mazda 3 2008 1.6
    Jan 2009
    Quote Originally Posted by iameldrin View Post
    Mazda 3 2008 1.6
    Inspect and/or replace the door rubber seal.
    Mazda 3 2008 1.6
    at higpitan ang turnilyong humahawak sa door handle.
    Ingress-egress thru the window. [emoji16]
    Depends. Is the door aligned? If not then replace the hinges (might be sagged down due to time, wear and tear) and then replace the striker mechanism if need be (might be loose already).
    Sep 2008
    Try wrapping adhesive tape around the fixed latch attached to the door sill.
    imho, there would be three factors:
    a. the alignment
    b. the rubbers
    c. the joints.
    Mar 2004
    For rattles, put sound proofing materials inside door panels.
    Jul 2013
    1. replace the hinges... old one may be sagging or too loose
    2. replace the seal... no idea where you'll find one, but make sure your using the original seal for your door
    3. car handles... replace the entire mechanism, some parts (inside) are plastic and may be loose
    4. replace the entire mechanism of the windows... same reason as the car handles...
    I did the same in the 90's for my box type... almost everything inside the door was replaced! sadly, my wallet only allowed me to fix the 2 front doors
    Silicon spray on sponge and clean the weatherstrip aka rubber. I do it twice.
    Silicon spray cans have a label. Read its recommended uses, most include weatherstrips. I use it to clean/detail the rubber. It doesnt last however.
    Wurth Rubber Care is hard to find in my area. It is specifically for weather strips. Maybe ask Wurth Philippines?
    Jan 2016
    Hodor and Clenly. Hold the door and Close gently.
    Apr 2016
    Hi guys, Thanks for all the comment to give you guys more info
    the loose door handle and the not refrigerator sound is from the driver side only the rest of the door are ok
    so any more suggestion, all i though that the sound is frm the door seals i didnt know there are more to it
Make the door sound new
