pare that looks more like the main fuse panel in the engine compartment, that is not where the cig lighter fuse is located.
the fuse panel you should be concerned with is the one inside the passenger cabin. it is usually located at the driver's side, just left of where your left leg would be (the reason they call it a "kick panel"). some cars will have it on the front passenger side also, or both sides. the plastic cover can be removed by just pulling it out, and on its back should be the fuse diagram telling you what each fuse is for and the amperage required.
Thank you very much sa reply, sir. Pinagbasehan ko lang po kasi yung owner's manual. As per the diagram, under Fuse relay location #7...doon po pinapakita yung location din ng Cigarette lighter.
I-check ko po yung kick panel.
Thank you very much po, sir.
