Results 1 to 13 of 13
    guys tanong lng, san ba mairerekomenda nyong maganda pagpagawaan ng wheel alignment? taga makati ako,, maraming salamat,,
    Apr 2009
    goodyear hehe kaso medyo mahal at hindi ko alam kung meron malapit diyan:D pero trip ko magapa-align duon kasi chinecheck muna nila kung mayroong mga sira suspension mo para gagawin muna yun para masiguro na hindi na mawawala sa alignment kotse mo ng matagal na panahon:D
    Nov 2007
    goodyear servitekcan do the job.
    Feb 2009
    Quote Originally Posted by Esnie.com View Post
    +1. Or Minerva Tyre Gallery. They have a branch in Macapagal beside the Petron gas station in front of Shell.
    Apr 2005
    Bridgestone sa The Fort.
    I just bought 4 195/55R15 Nankang tires for my Dad's Sentra as a gift. Premature kasi ang mga pagkaupod due to faulty wheel alignment done at his mechanic's shop (string method ). Now, I brought the car to our local Goodyear Servitek. After 15-20 minutes ay tapos na ang alignment + 1 camber correction (rear).
    Here's the problem: my dad claims that there were humming sounds now and some vibrations after the alignment. I test-drived it, kumpirmado! I brought it back again * the Servitek and after some test, the mechanic there said that OK naman yung ginawa nila. Must be the front wheel bearings daw.
    Heto ang FRONT alignment measurement nila:
    right side - +0.05
    left side - +0.10
    Mga bro, tama ba adjustments? Sa pagkaalam ko ay dapat NEGATIVE ang values? Kasi bubuka pa ang mga front tires pag sinakyan na.
    TIA !
    Jun 2010
    might be maingay ang Nankang tires mo. kung ugong ang naririnig like a "whirrrrrrrr" sound at lumalakas ang sound habang umaandar then confirmed wheel bearings nga.
    hindi dahilan ang alignment para magbigay ng ganung noise FYI.
    Tnk bro! Yung wheel bearing ang sira. OK na.
    As for the Nankang tires, they are performing quite well.
    Aug 2010
    ok ba magpa align sa zafra?
    Jul 2010
    Kapag magpapa-align, wag sa mano mano, dapat sa computerized medyo mahal pero sulit naman.
    Idagdag ko, kapag sinabi ng tech na papalitan na muna shock,coil springs ball joints tie rod ends, bushings bago i-align, sundin natin payo para isang gastos na lang...
    Sep 2004
    Quote Originally Posted by desert fox View Post
    Kaya lagi akong may nakahandang ball joint set bago ako magpapalit ng front tires sa Servitek. Fortunately the last tire change I had, ok pa yung existing ball joints.
    As a side note, I found that aftermarket ball joints (555) last way longer than OEM (Mitsubishi) ones.
    Jul 2010
    Quote Originally Posted by Bogeyman View Post
    Thats a good sign of a responsible vehicle owner..
    sa side note mo about replacement parts, depende din kasi yan sa manufacturer...me reliable at me di naman....
    sa 555 matagal na yan gumagawa ng piyesa...kaya tama ka dun, minsan mas matibay pa replacement parts kesa OEM....
    Ang ingatan lang ay yung mga fake parts na naka-carton sa OEM cartons, akala natin orig pero fake pala.....
    Quote Originally Posted by trucker111 View Post
    never ako mag papagawa sa zafra, mga manloloko mga tao dyan. mula sa mekaniko up to the manager....
    servitek ok pa
wheel alignment
