mga sir need ko input nyo.. Im planning to change my L300 VV engine. Which is better td27 turbo or 4d56 turbo. Pros and Cons mga expert. Thank you in advance.
I guess you'll be better off with a 4D56 turbo as it's the one made and fit for the L300 directly. The Nissan TD27, although its a much better engine for me in basic form against the 4d56, might need rework to fit your L300.
+100, although TS tandaan mo na mainit lalo sa makina ang turbo ha, kung same spec na radiator ka pa rin, baka kulangin cooling power mo. Less airflow din kapag L300 VV vs a strada or pajero na 4d56 turbo kaya kasama din sa sa consideration ha. Dapat alam ng mekaniko mo yan.
Quikc fix if gusto mo talaga ng may turbo ay;
a. make sure cooling system is in peak condition and use 50/50 coolant distilled water ratio.
b. install an oil catch can (search ka na lang dito or sa net kung ano yan)
c. if you can install a separate oil cooler then it would be really good for your engine.
d. Make sure to use only a CH-4 and up rated diesel multigrade engine oil for your engine and turbo's protection. A good oil filter like bosch, baldwin, fleetguard should also be used instead of vic, nippon, union japan etc. Stay away from daiwa filters. Search for remote bypass filtration here in tsikot for more knowledge.
4D56 is plug-n-play, I've even already seen some turbocharged L300 vans, but I'm still more favorable to the TD27. Its fitment is not so tighter at all, and it's more reliable. One feature I like is the chain-driven OHV valvetrain, which requires less maintenance.
Update ko lang ito. It cost me 20k pina linis ko ang buong system binukasan makina tinanggal laht ng oil. nag palit ng waterpump etc. Onti lang ang naging changes sa performance.
Sent from my GT-I9505 using Tsikot Forums mobile app
We have L200 changed engine with 4d56t w/o intercooler, share ko lang ang nagiging problem:
1. Cooling - di uubra ang stock radiator lalo pag natraffic kaw, lalo na kulob ang versa van
2. Lalakas sa diesel - for obvious reason more power = more diesel consumption pero may shops na kayang patipirin ito.
3. Braking power - di kayanin ng stock, madaling iinit ang brake.
Overall malaki nagastos para ma solve mga problem na na encounter. Kahit pug and play ang engine may extra ka padin mabayaran na unexpected.
Unless may katok na engine mo stay with you current engine nalang IMHO
Goodthing diko pinapalitan. 45d6 still reliable. Gumagamit nalng ako ng additives para mas swabe ang takbo at walang usok.
2t oil? Ngayun ko lang narinig ito. Kadalasan ginagawa ito sa 2 stroke na motor pero not in a diesel engine.
kung gusto mo lumakas ng konti hatak ng L300 mo palitan mo ng pressure plate at clutch lining na pang pajero. mas malaki ito compared sa stock mo. ganito ginamit namin sa Advie na pang pasada ng pinsan ko sobrang gaan manakbo kahit puno ng pasahero
