Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
    #21
    Quote Originally Posted by v6dreamer View Post
    You have only one timing belt its located inside the plastic covers on side of engine where the other belts are.
    Is it expensive? New engine cost more!
    TBs are not expensive. original belts are around 1.8k each, OEM. ang mahal lang is yung labor.. hehehehe. mga 1k din.
    pero yes, its more expensive magpa overhaul ng engine pag naputulan ka.
    #22
    ah...sir ung timing belt ko is BANDO ang tatak...while ung isang belt para power steering ay mitsubishi ang tatak...original ba ng mitsubishi ung BANDO? or aftermarket parts lang sya?
    #23
    Yun L300 ko naputulan 3 or 4 years ago...aabutin dapat ng mga 30k kung all original mitsu parts, kaso ako para maka tipid, hyundai valves pinalagay ko kasi mas mura at parehodin lang naman daw...tas with the machine shop at labor inabot lang ako 18k...Sa shell station ko pinagawa sa visayas avenue..hanggang ngayon ok pa naman siya...
    #24
    Quote Originally Posted by sum1_27 View Post
    sir kabibili ko lang kasi ng second hand car...2003 lancer GLS..65000kms na ang natakbo nung nabili namin nung december..naka 5000kms na ako. dapat na bang palitan timing belt? paano po ba malalaman kung original pa ung timing belt? bando ung tatak ng timing belt eh...ung isang timing belt wala naman akong mabasa.....
    bando is a replacement belt, not only for timing belts but for other belts (alternator, compressor). great non-OEM replacement brand.
    #25
    #26
    #27
    uy..bakit tatlong post? isang beses lang ako nag submit ah....
    #28
    ah...bale napalitan na pala ung timing belt ko? pero ung belt para sa power steering pump ay mitsubishi ang tatak?
    #29
    tingin ko, di pa din napalitan yan. better to be safe than sorry.
Timing Belt
