Page 6 of 7 FirstFirst ... 234567 LastLast
Results 101 to 120 of 704
    Sep 2008
    Sir kayo ung nagpapagawa din kay Jemson diba?
    Sent from my Nexus 7 using Tapatalk 2
    -Yes sir CB. Did we meet na po ba? Most of the time electricals..
    -Salamat po sir blue gambit. Actually that is the ride of my son, kaya lang I prefer to use it instead..hehe
    Lucent, subukan mo munang ipalinis yung lens at baka kaya pang luminaw. Tama si Falken, wagon kang mag H.I.D. kung wala kang projector housing dahil nakakasilaw yun sa mga kasalubong mo.
    Yung Pajero mo ba ay box type? Ipakita mo sa Mitsubishi auto supply shop para masabi kung kasya ba ang square na headlights. Pwede mo ring i post yung picture ng Pajero mo para malaman namin ang body type.
    Posted via Tsikot Mobile App
    Dec 2010
    Quote Originally Posted by Monty View Post
    Hanap ako ng marunong maglinis ng lens po muna. Actually, nakuha ko lang po yung unit na naka HID na. Kaya parang mas maliwanag at malayo pa ang nararating flashlight.Ni attached ko po yung pic for reference. Pag ala po akong nakitang marunong magluinis, no choice but to change the headlight. Pwede po ba e DIY yung cleaning ?heheheh
    Dec 2010
    Quote Originally Posted by lucent View Post
    Last edited by lucent; August 26th, 2014 at 05:55 PM. Reason: to enlarge the picture
    Sir palit ka na lang depo HL yung clear nasa 3.5k pair nung bimili ako a few years back .. mounts lang babaguhin mo pero it would be easier than openning ur current HL .. and for sure satified ka sa clear HL
    Dec 2010
    [QUOTE=blue_gambit;2392579]Sir palit ka na lang depo HL yung clear nasa 3.5k pair nung bimili ako a few years back .. mounts lang babaguhin mo pero it would be easier than openning ur current HL .. and for sure satified ka sa clear HL
    Thanks for the tip blue_gambit. Parang ganoon na siguro mangyayari. Replace ko na lang HL. Makisuyo naman sir kung meron kang chance na mag post ng pics ng HL/modification na ginawa mo for reference ko sana.
    Lucent, di ko kabisado yung housing mo. Yung bakal na naka palibot (yung nasa likod ng black part) sa headlight pwede bang matanggal? kasi pag hindi baka tama yung sabi sa yo na yung square headlight ay pang '92 and up.
    Yung sa D.I.Y., baka may makita kang glass/lens cleaner sa Ace o True Value. Kaya lang ang sa alam ko mula sa loob ang pag linis nyan kaya di ganun ka dali. Good luck!
    Dec 2010
    Mukhang naka fix nga po(white part kung saan naka bold yung headlight). Anyway try ko pong linisin muna. Salamat po ulit.
    Adjusted the tps sensor of the paj. Medyo mas maaga shifting nasa 2,000rpm but kapag pa-4th gear na mga 2,200-2,300rpm pa din. Ganun na siguro talaga. But worth the effort for me kahit baklas intercooler, madali lang naman.
    So dapat tama kickdown cable at ma-djust din tps sensor kapag old na engine.
    Aug 2011
    Sir ask po ako. Kelan po umandar ung fan ng intercooler natin? Parang d ko nararamdaman na umaandar ung sakin? 4d56 tdic 3 door po. Dati pag mainit makina pag on ko ignition umaandar sya ngayon d ko na naririnig na umaandar after a long drive. Any suggestions mga sir?
    Aug 2011
    Salamat sir. My tranny shift alot better. Its night and day difference. I put sp3 from mits. Mas mahal nga lang pero sulit. It costs me 585 per liter.
    Sep 2008
    i had the air-conditioning unit of my jdm 3 door pajero serviced this after after repair of the tie rod ends in the morning. madalas nawawalan ng hangin. upon check up ng technician the main culprit was the motor blower. wasted the raw ung armature. ang lamig na ngayon dati parang hilaw siya as per technician par lance..eto mga parts na pinalitan: expansion valve, drier & actuator/idle up
    Attached Thumbnails Attached Thumbnails 1424348869793.jpg   1424348928596.jpg   1424348961835.jpg   1424349200197.jpg
    Sep 2008
    here are some more photos i took during the repair:
    Attached Thumbnails Attached Thumbnails 1424349522037.jpg   1424349540394.jpg   1424349595064.jpg
    Nice! Lamig na nyan!
    Sa subic ba nabibili yung 3door pajero na bnew?
    Quote Originally Posted by beginnerz View Post
    Wala nang Bnew na 3d pajero sir, puro converted yan na 2nd hand na.
    Sep 2008
    Sir RT is right. Mine is converted from Subic. Redone the under chassis, interior & electricals to make it look like at least 85% original LHD..
    Yes sir RT. Ang lamig na niya. Pinatay ko three times kanina (night time) sa lamig..also lumakas yong buga ng air kahit #1 lang siya..
    May 2015
    Question lang mga Sir.
    Hindi kasi pajero ride ko, 97 Jdm Challenger (montero sport pag usdm). Hirap lang ako maghanap ng paris, like headlights tsaka Dashboard. San ba puede pumunta para dito?
    Sensya na dito ako nag post, konti lang ata kasi kaparehas ko na ride lol. Pero halos mag pinsan naman ang Jdm na fm tsaka Challenger.
    Tia
    Ask ko lang po. San po sa banawe maganda magpagawa ng sidings at dashboard ng pajero?
    Quote Originally Posted by chevychevy2011 View Post
    Sidings sa upholstery shop ... if me crack na dashboard have it replace na lang .. malamang basag na rin vents nyan ...
Subic Pajero & 2nd hand Myths, Experts & Shops
