Seek for advice po sana para maging okay takbo ng Old Strada Triton ko..naging masyadong matagtag after ng upgrade...
Nag change ako ng TJM leaf spring kasi dead o flat na stock leaf spring..with 2in lift ung TJM leaf spring so nagpalit dn ako ng rear shocks na Amada Xtreme..24.5in ata length if stretched..then sa harap is coil spring spacer, retained the stock coil spring and same shocks na gas KYB..
After po ng upgrade, sobrang stiff na takbo..need po advice mga sirs if ano mas okay palitan..thank you
