Results 1 to 12 of 12
    Apr 2012
    Good day. I'm driving a mitsubishi strada glx-v and I'm planning to change my tires to a much bigger diameter of 305/45R22. A friend told me that I will need to lift my truck about 2"-3" to accommodate this tires. I just want to ask for your opinions or suggestions on where I can get this suspension lift kit. I also want to know the pros & cons of each lift method because I heard that there are different ways that can be done to lift a truck.
    Aug 2003
    Change coil springs in front (Ironman/OME) or add a coil spacer. At the back you can change the whole leafspring, put lifting blocks, or longer shackles.
    Apr 2012
    *ek2jayvee
    Any idea on where I can buy and have it installed? how much would this upgrade cost?
    check jc garage at their facebook page. i think i've seen some there. hth.
    Apr 2012
    I'll check on it sir. Thanks for the info
    Apr 2012
    Sana may mga lifted strada owners na magbigay ng advice or comment. Calling the attention of strada gurus! :-D
    Apr 2012
    check out Jeff's Offroad shop in Baguio...
    Apr 2012
    I already did sir. Medyo malayo kasi kung ipapagawa ko sa kanila.
    Apr 2012
    Follow up ko lang ito baka meron kayo mai-advice. Thanks
    Aug 2003
    Taga-saan ka sir? Para maadvice ka namin. Why don't you try joining The Strada Club Philippines FB page so that they can answer your questions.
    Apr 2012
    taga-cavite ako sir. naghahanap ako nang magsusupply and install na ng lift kit. anywhere na malapit dito sa cavite or metro manila.thanks
    Apr 2012
    I have learned that the most inexpensive way of lifting a trucks body is the "coil spacer - longer shackle" route. My question is, meron bang bad effect ito sa suspension system at handling since stock shock absorbers ang gagamitin at mai-stretch out sya approximately 2-3 inches?
Strada Lift Kit
