Results 1 to 4 of 4
- Jul 2012
- 4
September 9th, 2012 09:20 PM #1Mga sir bago lang ako dito sa tsikot.com ask ko lang sana kung ano problema ng oto ko kapag bago ko istart ang ignition may naririnig ako na parang grinding noise sa servo unit at kapag naka on na engine kapag binuksan ko na AC may grinding noise sa compressor . Pls help naman mga boss . Thanks and godbless
- 52,698
September 9th, 2012 10:03 PM #2compressor bearing?
if you're lucky, the compressor and the pully/bearings come in two parts and can be replaced independent of each other.
if you're unlucky, it's a one piece construction and not at all cheap to fix.. as in.. throw away..
- Jul 2012
- 4
September 9th, 2012 10:07 PM #3Sir dr. D maraming salamat sa reply mukang malakihang budget kung sakali pala...
September 12th, 2012 04:26 PM #4
sa glxi ko, normal lang yung mahinang grinding noise kapag naka-on ang susi while waiting for the check engine light to disappear. umiikot na kasi ang plastic servo kit parts sa loob.
just seen a 10th gen cross 200,000 miles on reddit. is this a unicorn or has the cvt been proven...
All New 2016 Civic
