Results 1 to 10 of 23
- Feb 2003
- 144
August 4th, 2003 05:27 PM #1madami din ba parts and rear end na suspension ng paj? i hear a clanking (metal to metal or parang chains and shackels na tunog) sound pag tinalon ko ang humps ng mabilis...hmmmm
ok na harap ko eh, pinaayos ko na, upper ball joint, tie rod end, upper arm bushin, pitman arm, idler arm, tska center bushing daw..(ano man yun) halos naubos front end ko eh!
pinarepair mo muna kasi maghahanp pa ako piyesa..baka within this month mapapalit ko na to new parts =) para sabay sabay na lahat...
August 4th, 2003 06:40 PM #2
Bihira masira ang rear suspension ng Pajero. What kind of driving have you been up to lately? hehehe.
Check mo yung lateral rod and yung trailing arms. Baka sira ang bushings.
August 4th, 2003 07:58 PM #3
maki.. ganun din yung sa akin rear suspension problem ko.. buti na lang nag post ka.. makikihirt na lang ako..
he.he.he.
August 4th, 2003 08:17 PM #5
Otep:: madali lang ba palitan yung bushing ng lateral rod and trailing arms. maingay din yung sakin e. I replaced my stab links, malaki tinahimik, pero meron pa rin sqeaky noise.
- Feb 2003
- 144
August 4th, 2003 09:11 PM #6yeah may squeaky noise and clanking eh...
marwen, yung 3dr paj mo din nagkakaganyan? subic din kasi akin eh, 3dr din, pero yung tonka look
otep, pajerokid
driving?? after ko ipagawa yung front, tinatry ko i torture test yung paj, 3mos warranty eh...=) hmmm actually kasi medyo dati pa yan napapansin ko (clanking form rear), pero nung tumahimik na yung front end ko mas napapansin ko na cya ngayon...pero pag nakabukas lang yung bintana...pag nakasara wala na ako marinig.. baka nga bushings lang...readily avail. ba ito sa mga shops?
August 4th, 2003 09:43 PM #7
Maki:: Yung rear ng paje halos lahat ng noise diyan galing sa worn out bushings. Pareho tayo ng symptoms sa likod. :D
Meron dati sa akin na squaking noise and "thug" sound pag humps. Stabilizer links pinalitan ko ng orig... P300 x2, orig yung piyesa. I got them from Eldorado Megamall. Order basis sa casa.
The noise level of the rear is now within acceptable levels (for me) :D Wala na yung squeak sa humps and very light na lang yung "thug" .
August 4th, 2003 11:48 PM #8
Yung sa akin may naririnig ako only when I drive with the windows down and I hit something really hard (i.e. not braking for a speed bump).
Hindi naman ako gaano naiistorbo so hindi ko na masyado pinapansin.
- Jul 2003
- 579
August 5th, 2003 12:45 AM #9pajerokid madi lang palitan trailing arms. kaya lang kailangan machine shop yung bushings. may style din ng pagtanggal kasi pag tinanggal mo ng basta basta marami ka tatanggalin like tires and madidisconnect pa ang entire axle mo.
August 5th, 2003 01:44 AM #10
Bubbles::Thanks for the info :D Medyo hassle pala.... tsaka ko na lang palitan pag talagang maingay na.
