Page 1 of 2 12 LastLast
Results 1 to 20 of 39
    Jan 2012
    - pano po malalaman kung servo na ang sira?
    - magkano po ang oem na servo motor?
    - ok po ba ang repair kit ng serbo motor gano po katagal ang tinatagal ng repair kit and magkano po?
    - converted to idle, ok po ba yan?
    base po sa mga experience ninyo mga sir tnx in advance, i am planning to buy a second hand glxi alin man sa itlog or pizza type. Ito kasi yung common na naririnig ko about sa serbo motor ng GLXI
    Jul 2010
    ans. the car's idling is erratic.
    ans. around 7k and up
    ans. its a hit or miss. others say it doesn't last that long.
    ans. yup others prefer to convert to use an idle up instead. while others still prefer to buy a replacement servo motor.
    HTH
    Jan 2012
    last question po, pizza carb 1.6 or pizza efi 1.6?
    alin po ang mas ok sa 2?
    Jul 2010
    Quote Originally Posted by ruhtra View Post
    I suggest sir that you choose the pizza efi 1.6 over the pizza carb 1.6
    Jan 2012
    Quote Originally Posted by xtian119 View Post
    HTH
    last question sir, 1.6 carb engine vs. 1.6 efi engine ano madali i maintenance and ano sa tingin po ninyo ang maganda GL pizz vs GLXi pizza we all know na Glxi are all power yung advantage and disadvantage nilang 2, baguhan palang po kasi ako pag dating sa mga sasakyan and plan ko kasi bumili hindi ko lang alam kung ano ang mas ok kung mag carb. ako o mag efi.
    mas madaling mag maintain ng carbed, pero mas malakas sa gas.
    sa experience ko sa glxi namin,
    when we got it from baguio city two years ago, i noticed na fluctuating ang rpm, tapos kinailangan nasa 2000rpm para hindi mamatay ang engine. pagdating dito sa manila, pinatignan ko sa mechanic ko, binuksan at nakita na yung mga plastic parts sa loob nito ay cracked/wornout na. i bought an original servo repair kit sa shaw merchandising, P900+ din yun pero wa epek nung ikinabit na. since short ako sa pera nun dahil nasa P14,000 ang servo replacement nun, i read and learned about the servo bypass'. so i opted for the toyota/denso idle-up when installed, it bypasses the servo na and makes the engine work normal and stable. kinopya ko na lang ang DIY servo bypass ng kasama ko sa mitsulancerph (si danesjr). so far, wala na akong problem ever since kinabit ang bypass. regular change oil and tune up na lang palagi.
    my reference (from the DIY post of danesjr)
    materials needed:
    1. Toyota-Denso idle-up auxillary air valve (part no.) 88691-17030, last time I asked this sells for 750 petot sa evangelista
    2. 1/4" Fuel hose, mga 4 ft, 5 ft na bilhin nyo panigurado
    3. 2pcs 1/4" T-pipes, ask around aircon repair shops, they usually have this in stock
    4. zip ties
    5. gauge 18 wire para sa line going to the aircon compressor
    connect the lower hose to the T-Pipe tapping into the hose from the Valve Cover to the intake manifold
    http://i74.photobucket.com/albums/i2...sjr/valve3.jpg
    connect the upper hose to the T-Pipe tapping into the hose from the intake tube to the valve cover
    http://i74.photobucket.com/albums/i2...sjr/valve4.jpg
    another view (1st tpipe connected to idle up unit/intake tube/Valve cover)
    http://i74.photobucket.com/albums/i275/danesjr/989c.jpg
    The Toyota Idle Air Valve mounted. connect the ground wire to body ground, tap the positive to the magnetic clutch activation wire(commonly a red Wire on the compressor) will post pics of the wire where i tapped this.
    http://i74.photobucket.com/albums/i275/danesjr/6fae.jpg
    from another view
    http://i74.photobucket.com/albums/i275/danesjr/537b.jpg
    full view of the hoses connections and the second T-pipe connected to the idle up unit/PCV/intake manifold
    http://i74.photobucket.com/albums/i275/danesjr/d1ef.jpg
    http://i74.photobucket.com/albums/i275/danesjr/f993.jpg
    How to set Idle RPM.
    1. With aircon OFF set the Base IDLE by turning the BISS screw on the manifold.
    2. With Aircon ON turn the screw on the Toyota Idle Air Valve to get the desired RPM while aircon is ON.
    Jan 2012
    Quote Originally Posted by zero View Post
    sir magkano naman po ang nagastos ninyo sa pag bypass ng servo to toyota idle up?
    less than P1k ang nagastos ko,
    P600plus ang toyota/denso idle up (surplus)
    mga P200+ para sa fuel hose, t-pipes, and zip ties.
    Apr 2015
    sir, taga davao po ako, may kakilala po ba kayon na gumagawa ng bypass dito? lancer pizza pie glxi ung unit ko po.thanks
    Sep 2012
    Sir Zero
    Gusto ko DYI bypass ung lancer ko GLXI 94, ung photo bucket po na naka post di napo gumagana, ok lang po pa send na lang
    sa email ko rjanaban*yahoo.com Ung mga pics para masundan ko, maraming salamat master!..... Pwde bako sumali sa
    club nyo thanks ulit...
    Aug 2013
    Quote Originally Posted by racer3018 View Post
    Sir Zero
    sir pa send n din po s email ko kung papanu ng bypass for lancer n yan tnx. 1827togsanne*gmail.com
    Apr 2015
    sir,pakisend nalang den po sa email ko RICRO_20*yahoo.com. madami na pong mekaniko ang nilapitan ko sa servo problem ko po,until now,wa epek pa din...salamat po.
    Sep 2012
    Re: Lancer GLXI servo motor problem
    Sir Zero
    Dec 2015
    Sir Zero
    Sir may mga active ba dito need help sa lancer ko servo problem.thanks
    Dec 2015
    Bought a lancer hotdog nun una naka engine check cya tapos sobra baba ng rpm pag nag init na tunataas na cya pero once u on yun ac bigla bumababa,tsaka pag malamig makina sobra cya mausok tapos medyo di maganda amoy ng usok parang mlangis na sunog,tapos spark plug ko madaling magitim,nun una sabi sakin top overhaul,pero pina compresion test ko ok p nmn daw,ask ko lang sana pag sira ba servo possible yun din ba problema kaya nausok pag malamig pa makina.
    Jul 2016
    salamat po nakakuha ako ng mga idea
    Jan 2017
    Quote Originally Posted by YooShh17 View Post
    hi po san po may gumagawa ng servo bypass d2 sa san jose del monte, bulacan? tnx po
    Dec 2012
    the photobucket site does not show pic of ur convertion. could you email me these helpfull tips. admailnow*yahoo.com thank you for your patience. happy new year !!!
    Jan 2013
    Hi sir bago lang po ko dito sa tsikot.com nakita ko yung thread nato while browsing. this is a very usefull information. i have done the same for my glxi 94 model. nagOK na sya halos 1 year sya wala problem after mapa bypass ko yung servo. pero ngayon bigla na lang nag up and down yung rpm nya kahit na ka idle anu kaya sir tingin nyo naging problem? do you think its the denso idle-up? thanks in advance.
