Results 1 to 3 of 3
    Aug 2010
    [SIZE=3]Patulong naman po. I'm just a newbie here . This is my first time to have a mitsubishi adventure. I acquired it last August 5, 2010 at citimotors alabang. So bale presently ay 462Km pa lang ang odo. My problems are: [/SIZE]
    [SIZE=3]1. may napansin akong langis sa isa sa mga Hexbolt sa ibabaw ng makina (i dont know yung name nung part). And also, [/SIZE]
    [SIZE=3]2. sometimes may tumutulong green liquid sa ilalim sa harap ng car (mukhang coolant yata). [/SIZE]
    [SIZE=3]3. Kapag bagong start, may maingay sa may transmission na tumatahimik kapag inaapakan ang clutch. Pag matagal nang umaandar ay tumatahimik naman yata.[/SIZE]
    [SIZE=3] Ano sa tingin nyo ang problema ng advie ko mga guru's? Any input will be highly appreciated. Thanks po in advance.[/SIZE]
    Feb 2010
    Quote Originally Posted by namwah View Post
    sir, i think that's valve cover your refering with hex screw. (need tightening), green liquid is coolant leaking either the hose clip or your water pump. (need tightening and under warranty), maingay sa transmission sound like tak tak tak is release bearing. (that's normal sa transmission ng adventure if medyo used na. in your case at 462km, try to claim under warranty). sir, best way to do is bring your unit immediately to casa para ma address problem mo.
    Aug 2010
    [SIZE=3]Hello,[/SIZE]
    [SIZE=3]1. Hindi po normal to, pa check nyo sa CASA[/SIZE]
    [SIZE=3]2. Hindi po normal to, pa check nyo sa CASA
    [/SIZE]
    [SIZE=3]3. Normal po ito sa 2010 advie[/SIZE]
    [SIZE=3][/SIZE]
    [SIZE=3]Sir, join kayo sa http://www.mitsuadvclub.net .[/SIZE]
    [SIZE=3][/SIZE]
    [SIZE=3]Dami makaktulong sayo dyan.[/SIZE]
Please help on my Mit Advie 2010
