Results 1 to 10 of 10
    ask ko lang kong ilang Liters pag mag flush our monty...after we drain the oil...
    3L is oky na ba...
    thanks in advance
    Dec 2009
    ^engine flush is a concentrate cleaner which is added on to the engine oil to soften up sludge accumulated engine after a prolonged use. most dealerships prefer this because its comparatively less laborious than the use of low quality oil to flush out gums in your engine
    if you are preparing for a 1thou km PMS, its not that necessary since the engine is relatively new, its gum free. what is important is for the minute metal shavings be removed from your engine system, so you can optionally skip the flushing. just go for oil & filter replacement
    if you opt for mineral oil the dealership would offer additives for additional engine protection. fully syn oil already contain additives good enough for the protection of your new engine in the long run
    Using engine flushing on a relatively new engine is an unnecessary expense. Plain change oil and oil filter change will do. Just invest on a good oil (at least API CI-4).
    Jun 2009
    I am not into engine flush also. I just drain down my oil, no pressurized air. A friend of mine who is a a car dealer service manager told me that if you are using mineral oil you don't need to flush but if you are using a synthetic oil you have to.
    Nov 2007
    Quote Originally Posted by crv99ner View Post
    Whats the rationale behind sir??
    i also do not use engine flush or any additive. i also do not use pressurized air. just plain old ytivarg.
    and i always replace my oil filter, gas or diesel engine.
    i do not believe in additives of any sort. i just use the additive money to buy more fuel.
    whats the problem sir sa pressurized air..??
    Oct 2005
    Synthetic when taken for granted sticks and hardens.
    https://www.facebook.com/AutoEncorePhil
help me.....lapit na ang PMS ko..
