Results 1 to 3 of 3
December 12th, 2008 11:02 PM #1
Good Day tsikoteers
Ano kaya ang problema na Pajero subic namin 2.5 TDIC.
Kapag kasi malamig or galing sa garahe yung pajero namin 1 click lang start na siya , pero kapag pinatay mo siya or mainit na yung makina ayaw nya ng umi start , Kaya kapag may pupuntahan tuloy ako at kung saglit lang naman ako sa lugar na iyon e' hindi ko na pinapatay yung makina dahil nga ayaw umistart puro redondo' lang , minsan nga na-drain yung battery nya kaka-start ko..
Pina-check ko naman po yung magnetic switch yata yung tawag dun' o.k naman po , Ang sabi ng ibang mekaniko baka daw po sensor' yun. Sinubukan kasi nilang sprayan or buhasan ng tubig yung buong makina ko para bumaba ung temps. Ayung 1 click umistart na!!!
December 13th, 2008 04:46 AM #2
Possibly bad starter, - bushings and brushes may vbe getting "thin" sometimes they work better when cold than when hot (engine has less compression).
If the engine seems to crank at normal speed but just doesn't start, check your fuel filter. If fuel delivery problem , - it may start out real quick with just a small squirt of WD-40 in the induction tube! Use sparingly,- there is propane powering the spray-- a bunch could be hard on engine! If this fires it up quick,- then have your fuel system pressure checked, - possibly you have a bad valve in fuel pump or injector body, - that allows pressure to "bleed off slowly, - and engine has to build up enough pressure to "pop" the injectors to pump fuel into engine!.This is not common, -so most people overlook it for a while trying to find problem.
Ooh, one more thing, here's the situation simplified, "air and
diesel compresses", water doesn't. If water comes between combustion chamber you could hydrolock the engine and get to see what your connecting rods look like when they are pushed out of the side of the engine block. Do not allow that....pouring water on engine.
Automatic po Sir
