Results 1 to 13 of 13
    Mar 2004
    Pls. help w/ my pajero 2.5 tdic hirap magstart pag malamig ive already replaced my glow plugs. tapos when im in baguio tinulak na lang para magstart what must be the problem ive already have 111,000 on my odometer lose compression na ba ito? then also my break lights are not working. pag nag step ako sa breaks wala what might be the problem TSikoters :D
    brake lights = check bulbs, pag ok, check fuse, pag ok, check switch (sa pedal)
    hard start = baka loose compression na nga.
    Mar 2004
    Thanks pajerokid yung switch sa pedal pano maccheck ito TY
    Mar 2004
    nga pala is there a solution to bring back the compression
    Pa-compression test mo muna para malaman kung top o general overhaul ang kailangan.
    According to Haynes Pajero repair Manual
    sec 0-19 #4
    Engine Hard Start When Cold
    1. Battery discharged or low
    2. Fuel not reaching carb or fuel injectors
    (check fuel filter, lines, pump)
    3. Choke inoperative
    4. Defective spark plugs
    5. Diesel pre-heating system not operating properly
    double check lang muna lahat ng items above thats applicable to ur ride- just in case
    Pa-compression test mo muna para malaman kung kailangan na ang top o general overhaul.
    Baka glow plug relay lang ang problema. Either sira na or loose ang kabit.
    Btw, it is installed directly on your battery.
    Bakit may defective spark plugs dun sa Haynes Manual? :D
    Sa brake lights, naging problema ko din yan.
    Mali pala ang adjustment ng switch above the brake pedal. Inadjust ko and it worked fine again.
    Haynes manual topic of Hard Start When Cold
    covers all possible symptoms for diagnosis for 4g54, 2.5 & 2.8 diesel, V6
    ako rin na lito when going over the Troublshooting section detailing all the symptoms
    BUT per symptom points to a specific chapter covering your specific engine model/type
    general symptoms all lumped into one heading and refer to specific chapter for your model's recommended work/approach
    Jan 2003
    kung ok naman ang switch, fuse and bulbs. check the contacts of your brake lights. yung saken nabulok contacts kaya kinailangan palitan. bulbs were fine though. hehe :D
    tama si Otep... forgot to mention the Glow Plug relay.
    Mar 2004
    Thankyou so much for your helps! pa compression test ko muna!
    May 2004
    baka may air leak sa fuel system. you can check that by pumping the fuelfilter pump. pag sobrang lambot(walang resistance), me air leak. so it will take several seconds for the diesel to reach the injection pump during starting. very common to sa morning starts.
Help with my pajero 2.5 tdic
