Results 1 to 10 of 13
- Mar 2004
- 74
September 16th, 2004 03:41 PM #1Pls. help w/ my pajero 2.5 tdic hirap magstart pag malamig ive already replaced my glow plugs. tapos when im in baguio tinulak na lang para magstart what must be the problem ive already have 111,000 on my odometer lose compression na ba ito? then also my break lights are not working. pag nag step ako sa breaks wala what might be the problem TSikoters :D
September 16th, 2004 03:49 PM #2
brake lights = check bulbs, pag ok, check fuse, pag ok, check switch (sa pedal)
hard start = baka loose compression na nga.
- Mar 2004
- 74
- Mar 2004
- 74
September 16th, 2004 04:26 PM #5Originally posted by pajero gmbh
nga pala is there a solution to bring back the compression
- Sep 2003
- 287
September 16th, 2004 04:31 PM #6According to Haynes Pajero repair Manual
sec 0-19 #4
Engine Hard Start When Cold
1. Battery discharged or low
2. Fuel not reaching carb or fuel injectors
(check fuel filter, lines, pump)
3. Choke inoperative
4. Defective spark plugs
5. Diesel pre-heating system not operating properly
double check lang muna lahat ng items above thats applicable to ur ride- just in case
September 16th, 2004 04:33 PM #7Originally posted by pajero gmbh
September 16th, 2004 04:50 PM #8
Baka glow plug relay lang ang problema. Either sira na or loose ang kabit.
Btw, it is installed directly on your battery.
Bakit may defective spark plugs dun sa Haynes Manual? :D
Sa brake lights, naging problema ko din yan.
Mali pala ang adjustment ng switch above the brake pedal. Inadjust ko and it worked fine again.
- Sep 2003
- 287
September 16th, 2004 05:03 PM #9Haynes manual topic of Hard Start When Cold
covers all possible symptoms for diagnosis for 4g54, 2.5 & 2.8 diesel, V6
ako rin na lito when going over the Troublshooting section detailing all the symptoms
BUT per symptom points to a specific chapter covering your specific engine model/type
general symptoms all lumped into one heading and refer to specific chapter for your model's recommended work/approach
September 16th, 2004 05:06 PM #10
kung ok naman ang switch, fuse and bulbs. check the contacts of your brake lights. yung saken nabulok contacts kaya kinailangan palitan. bulbs were fine though. hehe :D
Thank you!
