Page 1 of 3 123 LastLast
Results 1 to 20 of 49
    Oct 2003
    Where can i buy bumper fog lamps for the Pajero bubble side 1999? Sobrang mahal sa kasa. Is it effective? Another thing I need is the power lock for the rear door. Mine is not working anymore and according to the Mitsubishi store in mega, it will cost 5000 plus. Actuator lang yon diba. Thanks
    try motorix banawe
    A generic acutator in Banawe just costs 120 including installations.
    There are lots of imitation foglamps in Banawe. I think the brand is Essuse. My cousin bought a set for his Lancer.
    As for the rear door, that is a common problem. Usually the actuator is not really broken. Just stuck. What I did was I took out the rear door panel (a pretty simple task) and then freed the actuator from its linkages. I pressed the lock/unlock button on my alarm remote while I was holding the freed actuator in my hands (the wire is long enough). And it worked. So I just lubed all the linkages again and put it back in. Now it works like a charm.
    Btw, a generic actuator will work on a Pajero. (just in case it is really broken)
    I got my Doorlock actuator for 4300, installed it myself.
    Sa foglamps, im not sure lang kun merong taiwan na pang pajero. havent seen any in my travels. But you can easily customize since lamps that size are quite common.
    kaya lang, hindi maganda yung taiwan na fogs! The Pajero's headlights are pretty good, you wont notice the fogs at all (i think).
    The reason why im saying this is because i had those taiwan fogs in my honda hatch..... good for looks lamang. But when honda sold off the orig lamps (P900 bucks lang! with harness), i got and installed it! Iba talaga orig!
    Mar 2003
    kailangan pa ata putulin yung parang grill sa corner bumper ng 99 model. nagtanong na ako before imitation lang 3th sa banawe.
    sa actuator kung kaya budget mo go for orig gaya kay sir pk. mas matigas pag replacement lang. lambot ng orig.
    Kung pang-rear door lang, ok na ang hindi orig. O kaya ilipat mo yung actuator ng tailgate dun sa rear door tapos yung japeyks ang ilagay mo sa tailgate.
    Oct 2003
    Thanks. My problem is the tailgate actuator. I know mura lang so I tried opening it up and the actuautor looks different compared to the actuators you can buy from any acc shop. Can you buy in banawe replacement parts for the pajero but looks exactly the same? What stores do you recommend? Regarding the foglamps, medyo mahina kasi headlight ng Pajero. I had the lens cleaned already, relay installed and Im using PIAA bulbs. Im not yet satisfied but I cant afford the HID lamps.
    If you can make it fit inside the space formerly occupied by the actuator, then it will work. Just make sure hindi reversed ang response niya sa commands from the driver's door.
    I even go to fit those Taiwan actuators on a Benz. Boy was that fun... hehehehe.
    promdiboy,
    yup, youre correct, the bumper corner protector has to be cut in order to install the fogs. Sa original kasi na merong fogs, yung buong rectangular na area around the said grille is covered by a plastic plate. San po kayo nakakita ng 3k na foglamps? pang Pajero talaga?
    Iniisip ko kasing lagyan nung orig fogs yung sakin eh, i'll get the corner protectors, and the taiwan fogs . (baduy ba Otep?)
    PK- if you plan to put projector lamps sa side bumper why not go na lang to the big ones ala PIAA. they will surely cost the same but the brightness will surely be better than the projector lamps.
    Well then it will be a hindrance when you go off road, but how many times in a month do you go off road, compared to the safety it will bring you when travelling at night.
    Mar 2003
    sir pajerokid
    sa procars sa banawe. sabi wala na daw wiring may connectors na raw na abang.
    Feb 2003
    wow just what i was looking for...=) foglamps! =) balak ko nga maghanap ng square/rectangle na fog lamps from some oem manuf like sa mga crosswind tapos custom fit sa pajero na yun... pero kelangan fiberglass paramalinis tingnan and mukhang seamless...may alam ba kayo nagfifiberglass dito sa san juan?
    Oct 2003
    Try 510 Auto Restoration in San Juan. Look for Louie Baltazar 7229084.
    Where is ProCars in banawe?
    Thanks ARB but i just want it discrete. R u from RATS Blue Ridge?
    OT: are you the levi of pdvd?
    Signature
    Nice suggestion sir ARB! I have grille mounted bosch fogs right now and im quite satisfied with them..... kaya lang i wanted to tone down the styling a bit and make it look more stock.
    sir promdiboy, thanks for the info!!! Kung P2000 yung gen2.5 bumper enders (x 2) plus + 3thou for the fogs..... 7thou lahat!!! hmmm pwede na rin pero check muna natin yung fogs.... minsan kasi di maganda quality ng taiwanese lighting eh
    Mar 2003
    turn right at mc do banawe. mga 2 blocks pa ata (not sure) nasa right side siya. lagpasan mo jaffas ng konti, wag ka lalagpas ng movenpick. look fo nick.
    magpapakabit na dapat ako pero ginabi pag install ng alarm, bili nalang daw ng oem na foglight switch para mas maganda.
    hehe.... yung orig na foglamp switch nasa P900 - P1500. half the price na nung foglamps
    Feb 2003
    san malapit ito?
    thanks
Pajero Accessories
