Page 1 of 2 12 LastLast
Results 1 to 20 of 40
    Feb 2004
    guys, next month, start na ang construction sa bahay ko and i am thinking of building a trailer for my pajero just so that i don't have to keep borrowing my dad's f150 if i need to carry loads and stuff.
    after finished ang bahay, i still plan to use this for dive tanks and dive gear and other stuff.
    do you guys have any suggestions? what platform should i use? multicab rear? target ko is a carrying capacity of 1.5 tons
    what do you think?
    andy
    A Pajero is safely rated to tow an unbraked trailer up to 750kgs. Anything heavier will require inertia or electric brakes.
    If I'm not mistaken, 5,000 lbs. is the max rating for a properly equipped vehicle and trailer.
    The standard pintle hook is not the best option for towing. You can replace it with a drop hitch (similar to the one offered in the U.S.) or a chassis mounted hitch similar to the one used in the Expedition/F150. This will allow you to use a tow ball which is better and safer for road use.
    Your trailer must also be equipped with brakes and the proper lighting.
    Feb 2004
    wow, 750 kgs lang pala kung walang brakes. parang speedboat lang siguro ito.
    hmmmm, in that case, maybe i shoud just build one from the rear of a multicab. magaan lang naman siguro you. maybe my target will be one ton total. 250 kgs for the trailer and 750kgs maximum load.
    what do yo guys think? is 1 ton total still safe or should i really just load it with 500 kgs max para shoot sa 750 kgs?
    andy
    750kgs is the safe limit for an unbraked trailer. You can tow more than that if you have a properly equipped and properly built trailer and mounted to your vehicle using a proper hitch mounting system.
    I have towed an unbraked trailer weighing over 750 kgs. It was ok on farm and dirt roads. But it can be a handful along the national highways. Getting up to speed is not as bad as you think. It's the braking that will require some skill and foresight. I could really feel the trailer pushing on me when I was braking on some of the down grade portions of the road.
    andy, sayang hindi mo nakita yung trailer ko dati pang hatak ng speedboat ko hehe.
    Feb 2004
    thanks otep do you think a rear multicab platform would be okay?
    andy
    May picture ako ng trailer sa bahay. Including the construction and design. I will scan it tomorrow. Dito kasi ako sa UST matutulog tonight.
    Aug 2003
    Boss Otep paano ba ginagamit yung ball hook (ganito kasi nakikita ko sa mga ford suv), diba lilipad ang lunette eye kung lalagay mo to from the trailer?
    unlike yung sa baba na may lock sa taas?
    kahit bumpy road oks lang
    Tnx po for clarifying...
    tnx tnx
    iba ang kapartner ng ball hitch, para itong laddle na exacto sa ball and meron lock mechanism...hindi talaga pang lunnette eye eto.
    otep,
    please email me a copy too the plans ng trailer...balak ko magpagawa para sa pick-up ko to carry/transport a toyota starlet....my email whyldthing*yahoo.com
    Aug 2003
    ngek yun pala yung nakikita ko sa mga A frame ng mga kasama ko sa LCCP Pampanga Chapter...kaya nag tataka ako bat ganon itsura non lols
    basta papatong mo lang sa ball then lock mo na sya?
    tow ball connector pala yon lols
    Thanks Wildthing :D
    yup self-locking yun
    wildthing,
    Uuwi ako ng bahay mamaya. I will scan the stuff for you guys.
    maraming salamas doc !!!
    there are trailers for rent at true value rockwell
    u may also want to check it out
    The photos are in my gallery. Check them out.
    Feb 2004
    i think i will stick to the 750 kgs gross that OTEp mentioned (kung walang brakes), i don't want this to happen to me
    http://www.synthx.com/articles/trailerhitch.jpg
    hehehehehehe, hanap na ako ng multicab
    andy
    Aug 2003
    haha naunang nag dive yung truck lols
    Feb 2004
    the manufacturer of that tow hitch and tow ball should use that as an advertisement for the strength of their product
    andy
    Aug 2003
    Nice Idea, Andy hehe ayus yun...
    Aint that your screen name "luckytruck"?
    Feb 2004
    yup, luckytruck din sya
    ako naman luckytruck dahil nung naka red f150 ako na 4x4, palaging swerte sa chicks. ngayon na naka gen 2 pajero ako, swerte pa rin kasi marami nang pang gasto kasi mura ang diesel and maintennance
    hehehehehe
    andy
building a trailer for my Pajero: any sugestions?
