Results 1 to 8 of 8
November 8th, 2007 03:25 AM #1
Hello All.
My Lancer GSR 2001 is emitting noise in the radiator fan. I checked for a replacement motor and it cost 7,500 ( replacement - Taiwan made ).
Do you think it is better to buy a surplus motor?
How about repairing the motor itself?
Thanks in advance for your replies.
November 8th, 2007 06:04 PM #2
try mo hanap sa iba ng radiator fan motor parang sobrang mahal naman yata niyan. just replaced radiator fan for honda civic (new rad fan) cost only 1500pesos.
November 9th, 2007 03:07 AM #3
I canvassed original Mitsu parts for radiator motor and fan and got lowest quote at 9,400 pesos., very expensive. I then went to Evangelista and found a good surplus motor and fan for 700 pesos. Add 300 pesos for mechanic home service so all in all I spent 1,000 pesos for the repairs. So far all is ok. Warranty for surplus parts is one week only.
- Apr 2006
- 5
December 6th, 2007 02:05 PM #4bago k magpalit ng radiator fan eh try mo munang ispray ng wd40 yung fan. ganyan din nangyari s akin at ok na fan ko. sayang money mo kung magpapalit k kagad!!!!!!!!!!!
June 30th, 2008 05:59 AM #5
i just sprayed my radiator fan with wd40, checked the relay. ayaw pa rin tapos dinala ko sa mekaniko, when they removed the motor and opened it up. sunog yun loob, sayang original pa naman. replaced the motor placed the fan blade ayaw umikot. turns out yun fan blade yun may kasalanan kaya nasunog yun motor. recommend have it checked, dapat the fan blade can move freely within its housing. cost me 1050 for the taiwan made motor (circuit yun brand)
- Dec 2008
- 1
December 25th, 2008 12:00 AM #6I recently had the radiator fan motor replaced also. It was squeaking so I figured it was the bearing inside the motor. I decided not to put oil because if I did, it will only lubricate the bearings but not fix it. The original replacement part from Honda, where I usually have my civic 92 fixed, is about Php10k. So I went to Banawe. I didn't get surplus motor because there's no way of telling how much longer those things are going to work and I might have to buy a second one later. So I got a replacement motor (Circuit brand) which the seller said is a good brand. Has anyone tried this brand? Is it good? I only need it to work for two years to consider it good enough.
December 31st, 2008 04:48 AM #7
Burberry Men Leather Jacket oskarjacket
Verifpro - paypal, ebay, banks, crypto, docs and...
