It's for cooling down the turbo. You set the timer to one minute (or more), remove car key, lock/arm your montero sport. Engine will continue running and shuts off automatically after one minute.
Turbos need to be cooled down after long distance driving or when you have driven with high rpm for a long time, not so applicable in city driving.
Hi Sir Garyq, I guess that's my ride. The output is quite impressive. The bluish color band at the upper edge of the light adds to the "cool" factor.
To all fellow tsikoteers, this is my first time to install an HID light. I decided to go the proper way. Proper way means a complete HID Projector retrofit. Result is a clean cut-off without any glare to opposite driver. I just hate those plug and play HID that give a lot of glare, whether they are at the opposite lane or behind me.
Wow that's nice. Tama nga si sir gary, walang sisirain sa OEM chrome assembly.![]()
BASH pLATES FOR NEW MONTERO SPORTS...
pm lang po if interested thanks...
( me ibang color pang available, powder coated or stainless steel )
nice one there, Master Sael! is that your Montero Sport? hehehehe...
also, what variant is this? I guess 2.5 GLS 4x2 A/T ito 'noh?
I presume that the bash plates you do for the Strada are very much applicable for the Montero Sport due to a very similar design on the first half. I'm wondering how will your tow hook fit the MS since the Spare tire is closer to the rear bumper. hmmm...
[quote=Reepicheep;1490614]Autoplus? Hehe
Thanks! Anything but the casa is worth considering for me!
hi,
paano pinapa linis aircon ng montero?
nasa likod lang ba ng glove box yun evaporator (easy access)? at hindi tulad ng mga toyota/denso ngyon an baklas lahat ng dashboard.
any non-casa aircon shop kaya ba linisin aircon ng montero?
thanks
Sir, question lang about your HID upgrade. All along I thought our montero was already equipped with projector headlamps, which meant the only thing we needed to change was the bulb itself - from halogen to HID. Now it appears that that's not the case.
Am I missing something here? Is there a difference between our stock projector headlamp and the HID projector retrofit being referred to above?
FYI, my car is a 2009 GLS 4x2 A/T model. Hope to get feedback on this. Thanks!
MS owners you might be part of a recall...
Check this
http://tsikot.yehey.com/forums/showt...50#post1496450
Hi Sir Kapitan,
Yes our Monty is equipt with "Halogen" projector headlamp. It is not the same as "HID projector headlamp". The light source of the former is based on Halogen bulb design and if you install a plug and play HID on a "halogen" projector, you still get undesirable glare and the light output is uneven are there will be "hotspot" (spots of intense lights) and the width is limited. I must however say that the glare caused by such a set up is limited compare to installing an HID on reflector housing.
Therefore a total HID retrofit by replacing the existing Halogen projector to an HID projector is the correct solution. This way, you get a beautiful light cut-off which doesn't cause glare to opposite traffic and you have an evenly spread light that is very helpful in night driving. The width of the light is also maximized as you can see up to 4-lanes of the road.
Hope this helps.
help naman... kung kayo ano pipiliin niyo pag change oil?
mineral oil every 5k reading, cost = 5k+++
or
fully synthetic every 10k reading (including top-up, change oil filter on 5k reading), total cost = 11k+++
Try this 3M. Very easy to apply and same results as yours. I tested it on my black monty and the result is very nice. Nawala yung rain spots na di kinaya nang turtlewax magic color pero nang ginamit ko ito tanggal ang rainspots, watermarks, light scratches at super kintab.
I was banned at the MSCP forms. I wonder what happened. My handle there is Degu.
Update:
It's fixed already.![]()
Check this Special Recall from MMPC to all Montero units which were sold from September 2008 to February 2009. http://www.mitsubishi-motors.com.ph/news/2010/page1.php
gud day mga bro... tanong ko lang kung meron na nabibiling antenna ng montero? kung meron mga magkano kaya? yung akin kase naputol.. tnx
