Hit the nail right on the headYou'll be better off getting the Unichip. A larger intercooler is just one piece of the 'go-fast' puzzle, it has to sync with a proportionally sized turbo to gain the results you want.
By the way, for those who want to squeeze more hp when testing your top speed, turn-off your airconditioning. You will feel the difference.
Fuchs ATF 4400 - Approvals & Specifications
Fuchs ATF 4400 automatic transmission fluid meets or exceeds the requirements of the following international and manufacturer standards:
- JASO M315 TYP 1A / JASO M315 TYPE 1A (JASO approved)
- DEXRON III
- AISIN WARNER
- BMW MINI 83 22 0 402 413
- BMW MINI 83 22 7 542 290
- DAEWOO
- DAIHATSU ALUMIX ATF MULTI
- FIAT TYPO T-IV
- FORD MERCON / FORD M2C924-A
- GM 9986195
- HONDA ATF Z-I / ATF Z1
- HYUNDAI SP III
- ISUZU BESCO ATF-II
- ISUZU BESCO ATF-III
- JWS 3309 / JWS TYPE T-IV
- KIA SP-III
- MAZDA ATF D-III / MAZDA ATF DIII
- MAZDA ATF M-3 / MAZDA ATF M3
- MITSUBISHI DIAMOND SP-II/ SPII
- MITSUBISHI DIAMOND SP-III/SPIII
- NISSAN C / NISSAN D / NISSAN J
- SAAB 3309
- SUBARU ATF OIL
- SUBARU ATF OIL SPECIAL
- SUZUKI ATF 3309
- SUZUKI ATF 3317
- TOYOTA TYPE T / TOYOTA T-II / TOYOTA T-III / TOYOTA T-IV
- TOYOTA TYPE D-2 / TOYOTA WS
- VW G 055 025 / VW G055025
Just want to share some pics of our Monty.. wala pa shadong upgrade, but we're working on it
Good evening guys, for those who are interested in buying montero im vouching for Ms. Emma Carpio at Union Motors Kalookan her cel no. is 09209550557.1day release. hehe (based from my own experience) paki sabi ni refer kayo ni Lj Pangan. hehe thank you mods im looking forward to see you guys.
karagdagang info sa ATF
[SIZE=2]TRANSMISSION FLUIDS
Over the years, there have been a confusing array of different ATF types and specifications. Make sure the replacement fluid meets or exceeds all OEM requirements. Using the wrong type of fluid may cause transmission problems and damage.
Type F -- Introduced by Ford in 1967 for their automatics. Also used by Toyota.
Type CJ -- Special fluid for Ford C6 transmissions. Similar to Dexron II. Must not be used in automatics that require Type F. Can be replaced with Mercon or Mercon V.
Type H -- Another limited Ford spec that differs from both Dexron and Type F. Can be replaced with Mercon or Mercon V.
Mercon -- Ford fluid introduced in 1987, very similar to Dexron II. Okay for all earlier Fords except those that require Type F. As of July 1, 2007, the production and licensing of Mercon ATF by Ford ends. Ford says applications that require Mercon ATF can now be serviced with Mercon V. See Ford TSB 06144 for more information.
Mercon V -- Replaces Mercon. Introduced in 1997 for Ranger, Explorer V6 and Aerostar, and 1998 & up Windstar, Taurus/Sable and Continental. This is the current ATF for most late model Ford products. See Ford TSB 06144 for more information.
Mercon SP -- Latest friction-modified ATF for Ford TorqShift Transmissions only. Do NOT use in transmissions that require Mercon or Mercon V. See Ford TSB 06144 for more information.
Dexron -- General Motors original ATF for automatics.
Dexron II -- Improved GM formula with better viscosity control and additional oxidation inhibitors. Can be used in place of Dexron.
Dexron IIE -- GM fluid for electronic transmissions.
Dexron III -- Replaces Dexron IIE and adds improved oxidation and corrosion control in GM electronic automatics.
Dexron III (H) -- Improved version of Dexron III released in 2003.
Dexron III/Saturn -- A special fluid spec for Saturns.
Dexron-VI -- Introduced in 2006 for GM Hydra-Matic 6L80 6-speed rear-wheel-drive transmissions. Dexron VI now replaces Dexron III and II, and can be used in GM or import transmissions that formerly specified Dexron III or II.
Chrysler 7176 -- For Chrysler FWD transaxles.
Chrysler 7176D (ATF+2) -- Adds improved cold temperature flow and oxidation resistance. Introduced 1997.
Chrysler 7176E (ATF+3) -- Adds improved shear stability and uses a higher quality base oil. Required for four-speed automatics (do NOT use Dexron or Mercon as a substitute).
Chrysler ATF+4 (ATE) -- Introduced in 1998, ATF+4 is synthetic and replaces the previous ATF+3 fluid. Used primarily for 2000 and 2001 vehicles, it can also be used in earlier Chrysler transmissions (except 1999 and older minivans with 41TE/AE transmission). ATF+3 should continue to be used for 1999 and earlier minivans because of the potential for torque converter shudder during break in.
NOTE:Chrysler ATF+4 Must always be used in vehicles that were originally filled with ATF+4. The red dye used in ATF+4 is not permanent. As the fluid ages it may become darker or appear brown in color. ATF+4 also has a unique odor that may change with age. Therefore, do not relay on the color and odor of ATF+4 to determine if the fluid needs to be changed. Follow the OEM recommended service interval.
Chrysler ATF+5 for 2002 and newer models.
IMPORT APPLICATIONS:
BMW LT7114l or LA2634 -- Special formula for BMW transmissions.
Genuine Honda ZL ATF -- Special ATF for Honda automatics (except CVT applications).
Mitsubishi Diamond SP-II & SP-Ill -- Special formula ATFs for Mitsubishi transmissions.
Nissan J-Matic -- Special formula for Nissan transmissions.
Toyota Type T, T-III & T-IV -- Special formula ATFs for Toyota and Lexus transmissions.
[/SIZE]
Marami na rin palang caviteno dito mini eyeball na. Kaya nga lang next month pa balik ko sa pinas.
Thanks for the info Lex. Good job on the chromed parts. Thats the key point with deep chromed parts. Sand it down thoroughly or else paint will easily chip off. In some cases even if the part is thoroughly sanded down, there are still chances that it "might" chip off due to the materials surface. Anyhow great job on your ride Lex.
Just a litte info regarding paint shop in citimotors makati. Some of us may know that it is not a mitsu specific paint shop as they accept services for other car makes. Heck they even specialize in highend luxury cars.
Moving on they avoid doing painting with chrome parts as they are worried that it may chip off eventually. Even if they did sanded down the piece thoroughly and no matter how good their painter and paint is. But if customer insists, they still do it for you and just inform them that should it chip in the future its not warrantied of some sort. It happened to a friends car per experience. Hope this helped...
hi guys,
* drivensteven, sir mic, navigator. thanks guys.
navigator, yep taga pasig din ako. De Castro to be exact.
Di ko pa natatanong kung gano katagal gagawin ung montero, sg-based na kasi ako since last year. kung nandyan lang ko, araw-araw ko siyang dadalawin![]()
Mga Sir, ask ko lang kung safe bumili ng Montero sport sa Union MOtors Paco? mau inooffer kasi sila unit. eh balita ko binaha yung dealership na yun...
Tnx For you reply in advance....
Thanks for viewing my portfolio site, sir!Wala po sa camera yan..ika nga, it's in the eye of the photographer that deals with a great picture
..let's do out-of-town photo-ops mini-EB with our monties someday. Open po sa lahat esp. to fellow MSCP members
(even if you're using a point & shoot, prosumer or DSLR cams).
Sorry mods..medyo OT po ito..hehehe
